3" hitch issues on 2018 F350
3" WHD review: https://www.ford-trucks.com/forums/1...ion-hitch.html
Thanks for the review and suggestions, I actually read your review earlier in the week.
I have a fair amount of money into the hitch I have and really feel like I need the sway prevention of the Hensley. I had/have a Equalizer hitch that I ran before and with this long/tall trailer and it's no comparison from a pivot point hitch to anything else.
Received 6,680 Likes
on
I will say I have never had "sway" (the tail wagging the dog) what I have is wind loading pushing the rear of the truck.
With the equalizer it was very bad requiring constant steering input from passing cars and trucks. With the Hensley the push is still there but doesn't really require effort to correct, it's more momentary.
on
Yes that's the way it seems...
The slop in the three pieces causes an issue. I somewhat expected it to be a problem but wasn't sure how long it would take.
I ordered a 2.5" Curt shank off Amazon this morning because it was "used" at $40 off regular price.
I will likely thicken that hitch with strips of cold rolled steel welded to it so I don't have to use a sleeve at all.
I am not really interested in swapping hitch styles again as the Hensley (pivot point projection) hitch is the only way I feel comfortable pulling this giant wind sock... I guess I could always sell it and buy a ProPride who does offer a 3" shank.
https://genyhitch.com/shop/weight-di...on-drop-hitch/
Even back in 2013 the cool kids were bending pins...
https://www.ford-trucks.com/forums/1...hitch-pin.html
I have received the CURT 17128 Weight Distribution Shank and will bill attaching a "permanent" 2.5-3" sleeve to it.
I will update this thread with the results.
Here is the finished product (untested as of yet).
I added some stainless shims to the 2.5" stinger before hammering the 2.5"-3" adapter on the 2.5" stinger. I then welded the 2.5"-3" adapter to the end of the Curt 2.5" stinger only. It would be easier to just weld the adapter to the stinger at the back and the front of the stinger making it one piece but that weld around the stinger would be a perfect spot to crack and snap the shaft.
I also made a shim top/side for the 2.5"-3" adpater in the trucks reciever hitch. The approx 16ga shim made the fit perfect with no up/down or side/side slop. The 3" reciever fits pretty loose to the adapter and my 3" weigh safe 180 hitch for my taste.
Stainless shims added to stinger.
Stinger/adapter effective length.
Welds on the pin sides only. Not really worried about the adpater slipping on the stinger I just wanted something to retain the adapter.
Finished product.
Finished product.
I have a 2017 F350 with a 3" receiver. I ended up getting the from Amazon. I ordered it and got it the next day. If you choose to go this route, I would advise to purchase a receiver lock. I am still waiting on mine to get here but got the https://www.etrailer.com/Hitch-Locks/Bulldog/BD580412.html from etrailer.com. That setup should be all you need and with that I'll never have to buy another hitch again. Hope this helps.
#28
#29
I am bending hitch pins as well. I have a 2" was hitch in a 2.5 with the reducer sleeve and have bent a couple pins as well as torn up the locks as slide back and forth and then grind away on the locking side. My hitch is ovalized and flared where the metal is deforming on the receiver hitch where the pin goes through as well. This is all with only a 6500 pound load. I believe this is all due to the play that you get with the reducers.
#30
