Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
hauling 3,500 lb trailer and 9,000 lb payload uphill
Old 03-31-2018, 09:45 AM
jdinvegas
jdinvegas is offline
jdinvegas is starting off with a positive reputation.
i have a 2005 Ford F-350 super duty turbo deisel, when do i use the "haul/tow" feature. my driver just came back to vegas from CA, he could not go faster thatn 35-40 uphill. but he did not know or engage the "tow/haul" feature. pls tell me that will help. jack
Old 03-31-2018, 11:17 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
I could tell you that will help, but I'd be lying. If he had the accelerator floored the tow/haul feature won't do anything to help. The truck is at it's limit and that's all the power it has. Tow/haul does not add horsepower.
Old 03-31-2018, 04:02 PM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
Did he manually downshift to third? That's what them gears are for.
Old 03-31-2018, 04:29 PM
Mark Kovalsky
If he had his accelerator on the floor manually shifting won't help. The trans will already be in third gear.
Old 03-31-2018, 06:00 PM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
Clubwagon is gaining momentum as a positive member of FTE.Clubwagon is gaining momentum as a positive member of FTE.
I assume that's a 6.0 diesel. 12,500 lbs isn't that big a deal for that motor. And once your through the Cajon Pass there isn't a significant climb.
Has the truck been serviced recently?
Old 03-31-2018, 08:22 PM
69cj's Avatar
69cj
69cj is offline
I never had that problem on the Cajon with probably 13 k behind me. I could hold 60 with my old 05. It was totally stock.
Old 04-01-2018, 07:25 AM
lynnmor
lynnmor is online now
lynnmor has a good reputation on FTE.lynnmor has a good reputation on FTE.
Tell him to use tow/haul when towing or hauling. DUH!
Tell him how to operate the long, skinny pedal.
I asked a guy, with a similar performance issue, if he had it floored and got a stupid look.
If the horsepower is indeed low, fix the truck. My bet, turbo issue.
Old 04-01-2018, 06:05 PM
Clubwagon's Avatar
Clubwagon
Yeah, but that's the only significant climb between LA and LV. I towed it with my '07 but the trailer was only about 9K lbs. No issues. It climbed it just like the Grapevine.
Assuming the driver wasn't out to lunch it could indeed be a turbo going bad. I did see a friend's 6.0 that had so many hose leaks that it wouldn't make much boost. We put hoses and clamps on it and it was right back to normal. He had been driving it that way for months thinking its just another 6.0 slowing dying.
Old 04-02-2018, 08:13 AM
UP_There's Avatar
UP_There
UP_There is online now
UP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud of
I'm wondering what type of EGT's he was having, and how much damage happened. Definitely something not right...
Old 04-02-2018, 09:16 AM
cappa
cappa is offline
cappa is gaining momentum as a positive member of FTE.
This would prob get more help in the 6.0 section. This is the 6.7 section and power is not a problem here.
Old 04-02-2018, 10:59 AM
Dakster's Avatar
Dakster
Dakster is offline
Dakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputation
Never had power issues with my 6.0 - something doesn't sound right. Granted this was back in 2005, to going on 13 years now since I last towed with one. Our resident Ford Transmission Engineer has already chimed in about tow/haul. I'll add some end user language though - Tow/Haul just changes how the transmission shifts, you can use it empty or loaded. Loaded I always use it - certainly helps in the stopping department - as the transmission holds the gear longer. (usually that's when I notice I forgot to turn it on on those occasions I forget)
Get it checked out. If it's bone stock and never been bullet proofed, you may be looking at some repairs (and I'd bullet proof it then too).
lbequ4002
09-24-2009 04:40 PM
lbequ4002
1999 to 2016 Super Duty
09-23-2009 07:17 PM
gt250
08-24-2007 02:29 PM
Picnic
17
02-02-2005 12:07 PM
ogre316
Ford vs The Competition
25
06-14-2001 08:51 AM
Quick Reply: hauling 3,500 lb trailer and 9,000 lb payload uphill
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
