3" hitch issues on 2018 F350
First short trip out (75 miles) using the 2" Hensley Arrow in the 2-2½ and then in 2½-3 sleeve it seems I have bent the oem pin and can't get it out of the hitch. I already new this would be a problem but I could not find a 3" WD hitch shank in time.
I can get 2½ shanks all day from several manufacturers but can't seem to find a 3".
Has anyone else had any luck?
Have you had any trouble using just the 2½ shank in the 3" sleeve?
I am thinking I would like to get away from sleeves all together but I could weld strips of steel to the 2½ shank to make it 3" or possibly just weld the sleeve to it...
Welding the sleeve to the stinger might be a solid option if hensley is not making one.
before doing that, I would contact the maker of the stinger you have to ask about a welding procedure. There may be some specific pre or post heat procedure to follow if it is anything other than mild steel.
Just my thoughts
Just my thoughts
Just my thoughts
Just my thoughts
Thinking about this more I might see the problem. The hole I am using in the stinger is a hole I added. I drilled it to the next size up I had from 5/8 so it's a tight fit. It may actually be holding the stinger in the center of the hitch tube so that when the WD was loaded up and then pulled out here I bet it bent the pin at the edge of the 2" stinger. I will get the 2.5" hitch and see how that all fits up.
Thanks for you reply though, sorry for the duplicates.
The WD hitch will get either the OEM 2.5-3" sleeve welded to it like you have done or I will build a tight fitting sleeve from strips of strap so that there is no slop between the sleeve and shank.
I like the latter idea so that I will still have a 2"-3" sleeve setup in case I have to use someone else's hitch or accessory in a bind.
Boomer23059
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
08-02-2011 06:06 PM
