Rebuild an F4 in 60 Days
#47
Just be glad that bearing retainer isn't for a T98...it took me 2 months to find a good one. Good news is I have a three of them stashed away under my bed in my college apartment. Sad part is you are about ready to pass me progress whys on my 50' F6 after 2 years. Keep up the good work!!
Sam
Sam
#49
#51
Personally, I'd be looking at replacing the starter (although that one unfortunately looks pretty new). The shaft is one piece from the bearing at the commutator all the way up through the armature and the starter drive. It is possible to remove the entire starter drive mechanism from the shaft, but the shaft is still integral to the armature. I think that it would be difficult at best to ever straighten that shaft enough to not have the drive wobble and hang up.
#52
#55
#57
Fine looking engine. Not to create a new challenge, but there is a heat shield on the intake that was originally on the 226 I6s. They often were removed and never reinstalled - giving you some sense of their perceived value.
http://www.vanpeltsales.com/FH_web/F...right_view.jpg
#58
Today's goals are getting the front axle back under the truck and sand the cab down to metal. I have 11 flap discs and a hungry angle grinder ready to go.
#60
3 weeks to go..
I was in Vegas this week so not much to report. Cab is almost down to bare metal, just the little corners where the angle grinder is too big to fit into remaining. Have some magical paint stripper helping me out too. Tomorrow and Sunday are 8 hour days minimum on this thing.
Anyone have input on painting the truck as a unit (mounting all the panels back on the truck and moving the truck into the booth) vs. painting each body panel separately and hanging them after they dry?
I have all the rear drum screws drilled out but still can't get the shoes off yet.
