1948 Ford Herrington Step Van....how rare?
It’s the only one I’ve seen. Is it yours? With the special body, winch, tow hooks, wheels like I’ve never seen, and military NDT tires it was special ordered for some serious purpose. I’m gonna assume F-3, but it’s hard to tell the truck’s wheelbase from an angle. A 122” would be F-2/F-3, and 134” would be F-4/F-5. Do you know that it’s a 1948, or could it be a 1949 or 1950? Being that it’s a CA truck it could have been a geological survey truck, utility company service vehicle, or similar. Is there M-H badging that you can post the numbers from, as well as the truck’s serial number? And if it is yours and you can get under it, please see if you can find a prominent three or four digit number stamped into the long tube of the front axle. F-3 M-Hs’ front axles are numbered, and seemingly installed in number order. I’ve kept an archive of those found that might help give an idea of its year. Stu
It's not mine, a friend is looking to buy it. I know Ford trucks more than him but I was mystified. I don't have access to serial numbers but it does have the badge on the hood and the badge on the glovebox. It's very original. I think that's a spare wheel on the roof and not a turret. (I did find a pic online that matches it and so there must be at least another one out there. White van.) Here's the interior of the van we've found:
The sticker CORVA in the rear window stands for California Offroad Vehicle Association. Or
some sort of Oil Drilling company.... Or it means prostitute in Yiddish. Or if you are into Star Wars...
Corva was a planet in Corva sector's Galaanus system. The Galactic Republic established a colony on the planet which
was wiped out by clodhoppers which arrived in a grain shipment. The clodhoppers ate all the vegetation on Corva as well as 87% of the colonists
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Got an email from one of our M-H guys about the wheels. They look like F-2 M-H style Budd 47210s, but if I’m seeing right have split outer rings. The 47210 has the Firestone RHP solid ring rim. So it sent me back to the books. Budd shows two SRW style 16” wheels having the Goodyear LTS split ring type rims. Number 68210 has a 6.00G outer rim, and number 60670 has a 6.50H rim. We’ve never come across these before, but it makes sense that the bigger model truck would get a wider set of rims. Stu
