Here is the crap that came from my gas tank
#31
I had a lot of crude in my Model "A" tank since it had sat for years with old fuel in it. I didn't want to remove the tank (a major project) so I used lacquer thinner to try and loosen things up. It worked fairly well although there was still some fine rust particles that occasionally clogged up the filter in the carburetor. I ended up buying an in tank filter that fits into the intake opening of the shut-off valve at the bottom of the tank. It prevents the stuff that's settled to the bottom from going down the fuel line. I'm not sure if something likes this is available for the F-1 but it's worked well and haven't had a problem in about 25 years.
#32
Silver54, that fuel outlet fitting looks nice, thanks for sharing the tip on that. Dan, that Model A filter is a good tip too.
Kevin, you are not late to the thread - the light is still on and I'm still gathering info on what to do next.
Harrier....you are welcome to talk to my wife about her version of events when I was shaking the tank. It could be entertaining to hear her perspective on the racket and mess I made.
The lowest priced stock style tank I have found is $249 plus shipping. I like to re-use original parts whenever possible and take pride in that part of a restoration, so I'm weighing the cost of treating the tank interior with the likelihood of success against the benefit of having a new tank or installing a non-stock one under the bed. I don't have good fabrication skills or tools and more importantly - have more time than money to spend on this project.
I just don't want to have a clogged carb jet while on a road trip.
Keep the info coming guys....I'm still on the fence.
Tom
Tom
#34
Tom
Tom
#35
Put some ethanol gas in it and let it soak. Even better put E85 if you have it. The ethanol will do some cleaning as well.. I think 200 to 300 bucks is cheap insurance that something will be reliable for the rest of your life. I still suggest you bite the bullet and get a new tank. If it was 1956 or whatever, they wouldn't hesitate to replace the tank if it was full of crud, original or not.
#36
Been through this with a couple different flatheads, my latest '49 I pulled the tank and attempted to clean it multiple times. After plugging up the carb and ruining the fuel pump https://www.jamestowndistributors.co...ter+SeparatorI installed a suction side fuel filter .
It done the trick, I haven't had to replace the fuel tank yet, but rolling marbles or anything else will definitely find any thin spots and leak sooner rather than later. I would pass on the tank coating.
There is a guy here in town who specializes in refurbishing fuel tanks, his suggestion to me was if you can buy a new one than do it. He estimated it would cost me over $500 to refurbish my tank, a new tank is cheaper.
#38
I ended up buying a new tank today.
Well after much thought I realized that re-using this tank is not the way to go.
Most of you guys advised against saving it and I do value your experience and opinion.
So I just ordered a new tank from LMC truck a few minutes ago.
Also ordered a new sending unit, brass float, gaskets, rubber bumpers and floor seal. It was way over $300 for everything but my old tank was just too corroded inside. Even after I power washed it and let it dry indoors for a few days, the rust particles would keep flaking off. The final nail in the coffin was the outlet hole at the bottom....I don't think I could ever get the sealer to adhere to that recessed area.
Aside from the expense, I shouldn't have any regrets and this new tank should last another 30 years or more.
Thanks again for all your advice, tips and stories.
Tom
Tom
#39
#41
Received 4,130 Likes
on
#42
I had not yet chimed in Tom, but I think you made the right decision Just one comment on the sending unit. If I remember correctly LMC did not send me instructions with my sender. The first time I just put it in as I received it. I later learned that there is a adjustment that needs to me made based on the depth of your tank. The directions can be found on the MidFifty Web site under Instructions. Maybe you already know what your doing but just though I would share in case you didn't. Dave
#43
on
Although you will never really know , I believe it's the right decision . These old vehicles are a challenge at the best of times with things that are out of your control or missed , this will be one thing off of that list . I often ( as you did ) think " I can make this work " but then think if I was stopped on the side of the highway many miles from home I would be more than happy to hand someone x amount of dollars to have me instantly running .
#45
I'll give the old tank away to anyone who wants it. Although a bit rusty inside, it is very clean and smells like Dawn dish soap instead of fuel. Personally I believe it would be great for smuggling dry contraband in your truck such as live exotic reptiles, rhino horn powder for Japanese male executives with limp appendages, bitcoins, salvaged shipwreck gold, Egyptian child mummies, presidential campaign banners, Cuban cigars or Canadian passports.
Tom
Tom
