2011 F250 Oil leak!!! Need help
Old 03-28-2018, 08:57 AM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
DeeDubz is starting off with a positive reputation.
I read the forums pretty regularly and never heard of anything about the 2011s vacuum pump bolts getting loose. I guess that will be one more thing to check when I do oil changes. What other issues are their with the 2011s? is their a thread dedicated to it?
Old 03-28-2018, 08:38 PM
Troy Buenger's Avatar
Troy Buenger
Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
Yep pretty much a 2011 issue as they were improperly torqued from the factory. I seriously doubt you'll have any more problems.
Old 03-29-2018, 12:18 AM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I'll add that I'm certainly not worried about checking it every oil change. I have not checked it since July.
Old 03-29-2018, 08:27 AM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
what are the torque specs?
Old 03-29-2018, 09:43 AM
m-chan68's Avatar
m-chan68
m-chan68 is online now
m-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputation
89 inch-pounds.
Old 03-29-2018, 09:47 AM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
Thanks, I haven't had a chance to inspect their work. I hope for the money I paid they cleaned up the mess.
Old 03-27-2019, 10:23 PM
Camper Bill
Camper Bill is offline
Camper Bill is starting off with a positive reputation.
I experienced the same oil leak on my 2014 F350 over the last two weeks. I self-diagnosed the issue as the vacuum pump bolts by reading the forums. I took it to Vista Ford in Oxnard, CA this morning. I told the service advisor about what I thought it was and asked him to check warranty coverage as well. My truck is 59 months old with 49,900 miles. They added dye to the oil and checked for leaks with a black light. It did turn out to be leaking at the vacuum pump. They replaced the vacuum pump gasket and were able to get it covered under the powertrain warranty. All is good!
Old 03-28-2019, 06:12 AM
fordboy2's Avatar
fordboy2
fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.fordboy2 is gaining momentum as a positive member of FTE.
Where’s the vacuum pump at? I want to check mine and make sure they are tight.
Old 03-28-2019, 03:20 PM
dirthawg's Avatar
dirthawg
dirthawg is offline
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
https://www.ford-trucks.com/forums/1...l#post18562823
RobRoy32
6.7L Power Stroke Diesel
04-18-2017 07:16 PM
Iron lhorse
Ranger & B-Series
09-25-2016 07:02 PM
GlennSwett
41
04-10-2016 07:12 PM
Diablo540
03-05-2014 12:23 PM
BanksPSD
18
03-24-2008 10:46 AM
Quick Reply: 2011 F250 Oil leak!!! Need help
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
