Drilling out Rear Drum Screws - Page 2 - Ford Truck Enthusiasts Forums
Old 05-15-2018, 01:39 AM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.
I'm a bit confused about exactly which part you're trying to get off now. Are you trying to get the axle shafts out? Some of those old axles have cone shaped bushings under the nuts or bolts that hold on the axle shafts. They are #1142 in Mark's picture above. Once everything is tight, those suckers really get wedged in there. They look like this:
The best way I've found to get them to loosen up and pop out is to tap on the side of the flange of the axle shaft. If you follow the arrow from #1144 in that picture, smack the tar out of it right there with a brass mallet all the way around it's diameter. That's usually enough to loosen them up and get them to work out of the tapered holes.
Old 05-15-2018, 12:41 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold
You can also swat the center of the end of the axle shaft two or three times with a hammer. The cone washers will bounce out far enough to be able to pull them off of the studs with a pair of pliers.
Mark
Old 05-15-2018, 01:00 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Journeyman Apprentice
Mixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud of
If your holes are centered pretty well in those flathead screws, I'd just go after them with an 82 countersink and remove the heads altogether. Forget about the threaded part.
Old 05-15-2018, 02:50 PM
acl9865's Avatar
acl9865
acl9865 is offline
acl9865 is starting off with a positive reputation.
So in my stupidity I managed to shear both adjustment bolts, the big ones with the springs behind them, and now the drum wont turn at all. Guessing I adjusted the shoes all the way out and then sheared the bolts.
Scale of 1-10 how screwed am I?
Old 05-15-2018, 03:07 PM
Jafo56's Avatar
Jafo56
Jafo56 is offline
Jafo56 has a very good reputation on FTE.Jafo56 has a very good reputation on FTE.Jafo56 has a very good reputation on FTE.Jafo56 has a very good reputation on FTE.
I just drilled my screws out yesterday!....... take your time...drums came right off....
Old 05-15-2018, 03:10 PM
Mixer man's Avatar
Mixer man
OH NO!
Twenty. I don't see an easy way out now. You're out a backing plate now regardless, unless there is enough adjustment left on the anchor bolt eccentrics to back off the brake shoes. Even that is going to be iffy.
Old 05-15-2018, 04:53 PM
49fordv8f4's Avatar
49fordv8f4
Those top adjustment bolts turn cams that adjust the shoes toward the drum. Since you twisted the bolts off, you may be able to take a punch and drive the cams in and out of the backing plate so the shoes will collapse inward. I have quite a few of those backing plates if you are in need of one. Again, I would not make any more attempts to remove the drums from the hubs, to keep from damaging them. I would remove the hubs and drums as an assembly.
Mark
Old 05-15-2018, 09:02 PM
acl9865's Avatar
acl9865
acl9865 is offline
**** it. Called the local classic car brake shop and they told me to bring it in. $100 and they'll get me where I need to be.
Old 05-15-2018, 11:38 PM
49fordv8f4's Avatar
49fordv8f4
Will they remove the drums without damaging them?
Mark
Old 05-16-2018, 09:37 AM
acl9865's Avatar
acl9865
acl9865 is offline
Mark
They're the most highly regarded classic car/truck brake shop in the area so I'd bet if anyone could it would be them. Let's find out!
Old 05-16-2018, 12:08 PM
Mixer man's Avatar
Mixer man
Fingers crossed.
Old 05-24-2018, 07:39 PM
49fordv8f4's Avatar
49fordv8f4
Alex, Any word on your brakes yet?
Mark
  #28
Old 05-24-2018, 07:45 PM
acl9865's Avatar
acl9865
acl9865 is offline
Mark
Not yet. Been busy with body work and life. I'll probably try to get the rear end off the truck this weekend and see if I can wrangle it to the shop somehow.
lee
05-07-2018 11:04 AM
Marauder2004
09-03-2013 09:44 PM
hollenjoe
02-25-2009 12:00 AM
bdonalds
10-30-2001 11:13 AM
Quick Reply: Drilling out Rear Drum Screws
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
