Sponsored by: Real Truck
4x4 Issues
Old Mar 23, 2018 | 12:00 AM
Joseph Schultz's Avatar
Joseph Schultz
7th Gear
4x4 Issues
Good Morning, All.
I recently purchased a 2008 F350 PSD (I know, I know...) with ESOF 4x4. When I turn the dial absolutely nothing happens. No lights, no noises, no 4x4. Along with that the tow/haul mode, and reverse sensing system are not functioning. I checked fuse 35 in the passenger kick panel that has these items listed but found no issues. Has anyone else ran in to this issue? I imagine that there is another relay or fuse somewhere else that needs to be checked buy I do not have an electrical manual or fuse map.
Thank you for any help!
Old Mar 23, 2018 | 12:17 AM
StrokinHer01's Avatar
StrokinHer01
Could be vacuum electronic mechanical ... mine did this so I threw the **** away and installed a toggle 4x4 switch... I stopped messing with my esof along time ago couldn’t figure it out ... sorry can’t help you on this one cause I got pissed off and stopped but have fun with that!
Old Mar 23, 2018 | 03:19 AM
seville009's Avatar
seville009
Switch itself could be bad. Many threads on this. Was it working for the prior owner? If you bought it from a dealer, maybe you still have a warranty.
Old Mar 23, 2018 | 03:33 AM
Joseph Schultz
7th Gear
Thanks for the replies! Would the switch being bad affect the tow haul mode and reverse sensing system, as well? Or do you think those are coincidental issues?
Old Mar 23, 2018 | 04:46 AM
seville009's Avatar
seville009
i’m no expert, but i’d think they were separate issues.
For the reverse sensor system, the sensors die fairly quickly. I have a 2006 and 2011 F350s with the reverse sensors. Had multiple sensors replaced on both trucks when the warranty was still in effect. Once the warranties were over, i didn’t bother replacing them anymore. They’re dead in both trucks now. The 2011 has a back up camera though which works fine.
Old Mar 23, 2018 | 08:09 AM
sxrfun's Avatar
sxrfun
There's also a power distribution box under the hood. Don't have access to my owners manual right now...so not sure if there's a fuse for these systems in there or not.
hiphopper00
Apr 27, 2023 05:30 AM
Governor801
1997 - 2003 F150
Jul 26, 2016 08:53 PM
dryfly
Feb 25, 2012 07:28 AM
that_one_guy
1997 - 2003 F150
Oct 7, 2008 06:18 AM
Montana2mass
Sep 25, 2008 02:20 PM
