Raptor Steering Wheel Swap
#31
I am referring to adaptive steering not adaptive cruse control. The adaptive steering is part of the steering wheel on my truck. It's all molded in to the wheel. I'm not sure if that can be switched out or not. Looks to be all part of the wheel. Idk though I've never had it apart compleatly.
#32
#33
The control bezel on your steering with their respective wiring harnesses are switched over to the new raptor steering wheel making it plug and play. This keeps the unique options specific to your truck intact. The Raptor steering wheel can be purchased with heated function with 4 different configs
#35
The swap will not work, I tried it about a month ago. The F150 and SD use completely different airbags. The F150 airbag has two plugs and the SD has one plug. The SD airbag will not latch into the F150 steering wheel. You will also loose adaptive steering if you have it as the motor is mounted in the SD steering wheel.
#37
#38
#39
F150 airbag has two plugs, SD airbag has 1 plug and a ground wire. SD airbag will not latch into the F150 steering wheel.
I have a raptor wheel in my garage.....just doesn't work.
#40
Yes, but I could care less about loosing the SD adaptive cruise as its not really adaptive compared the 150 version which will actually correct the wheel instead of just vibrate to let you know you are out of lane. I would much rather have the raptor wheel then a wheel with a vibrator in it. The airbags are the real problems.
#41
#43
Adaptive cruise control.
Adaptive steering
Lane keeping assist
As posted above, raptor can be had with adaptive cruise control. No issue there.
A swap will affect adaptive steering, as it is not an option in the F150
Lane keeping assist is just a small vibration in the SD. Not sure how it is implemented in the 150.
#45
three different things here.
Adaptive steering
Lane keeping assist
