Raptor Steering Wheel Swap - Page 13 - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
  #181
Old 10-06-2018, 11:54 PM
Tricon's Avatar
Tricon
Tricon is online now
Tricon has a good reputation on FTE.Tricon has a good reputation on FTE.Tricon has a good reputation on FTE.
Originally Posted by gravedgr View Post
Are you saying that when you swap buttons, it swaps the entire button structure (cover, sensor and rebound mechanism)? I know you said the action of the Raptor buttons was aesthetically better, but I would want the S/D button covers. For instance, I don't use cruise control often and would tend to forget which buttons did what with the Raptor button covers. However, I might reconsider if I had to swap over the entire button structure instead of just the button covers.
All of the buttons are exactly the same except for 3. The middle button on the right D pad has a voice activation icon, but in SDs it's the stereo mode button. The voice button is the top right and the mute button is the top left, on the right side cluster. They still work as they normally would, they just have the wrong label. All of the cruise control buttons and all the other buttons work and are labeled correctly.
You can't easily swap the button covers, you have to swap out the entire cluster. My XLT buttons felt a lot more "clicky" like a mechanical keyboard switch. The raptors are a lot smoother, it might've just been my wheel, but it feels like a higher quality action.
  #182
Old 10-11-2018, 07:57 PM
emanaresi
emanaresi is offline
emanaresi is starting off with a positive reputation.
Is there any chance at all that an XL would be able to be adapted to the heated wheel?
  #183
Old 10-11-2018, 11:09 PM
gravedgr's Avatar
gravedgr
gravedgr is offline
Likes to go fast
gravedgr is starting off with a positive reputation.
Actually, the only buttons that match mine at the D-pads (excluding the right D-pad center button), the phone pickup/hang up, and the cruise Set + / Set -. There rest of the bottom buttons are wrong (4/6 + D-pad center = 5 incorrect graphics). If the D-pad ring/center are separate buttons, that is 5 right and 5 wrong.
  #184
Old 10-11-2018, 11:37 PM
jonathanjr1's Avatar
jonathanjr1
jonathanjr1 is offline
jonathanjr1 is starting off with a positive reputation.
maybe but i'm not shure. I added it to my lariat value package.
  #185
Old 10-11-2018, 11:47 PM
STIBUILDER's Avatar
STIBUILDER
STIBUILDER is online now
STIBUILDER is starting off with a positive reputation.
Is it possible to just add the paddle shift? Would be super nice to have when towing in manual mode.
  #186
Old 10-12-2018, 12:11 AM
jonathanjr1
ya you just need the raptor wheel and to either buy the terminal pig tails from ford and splice them into the wires from the gear shifter or buy the plug and play harness 2016boostedgreygoose.
  #187
Old 10-12-2018, 09:21 AM
GABAR
GABAR is offline
GABAR is gaining momentum as a positive member of FTE.
Anything is possible but i`m sure doing this would require not just a heated steering wheel but also wire splicing and some kind of switch to turn it on and off.
With that being said, the cheaper option would be a nice pair of gloves.
  #188
Old 10-12-2018, 12:31 PM
jonathanjr1
no switches required only sync 3 and some forscan, total cost to add it into my truck was $530 after selling my factory wheel and that includes the raptor steering wheel. Here the google dock i made with all the information on adding it.
https://docs.google.com/document/d/15IW-hv1rVLkygN8qvvM45UjENexfbtMCr3NNv2uWrzw/edit?usp=drivesdk
  #189
Old 10-12-2018, 12:41 PM
18SD_Lariat
18SD_Lariat is offline
18SD_Lariat is starting off with a positive reputation.
https://docs.google.com/document/d/1...t?usp=drivesdk
I bought a PNP harness from Jon. It worked well except I needed to get into the MS-CAN differently than his directions because my 2018 didn't have the connector and I ended up making one that plugged into the trailer brake controller.
  #190
Old 10-12-2018, 06:03 PM
PSM 6.4
PSM 6.4 is offline
PSM 6.4 is starting off with a positive reputation.
Got BGG PnP harness installed in 5 mins. Thanks Lawrence ! i'm glad I waited for the new PnP harness and not use the v1 harness.
Its as easiest as can be to install.
  #191
Old 10-12-2018, 06:08 PM
2016BoostedGreyGoose
2016BoostedGreyGoose is offline
2016BoostedGreyGoose is starting off with a positive reputation.
Nice! Congrats, and thank you for the trust!
  #192
Old 10-12-2018, 06:54 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is online now
ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.
I almost didn't get mine installed today. It took me forever to get the airbag out of my stock steering wheel. No matter how hard I pushed, it would not release! I finally got a T-handle allen so I could really get some force behind it which (barely) did the trick.
I still need to get the harness from the goose!....I was waiting to get my wheel installed first.
  #193
Old 10-13-2018, 01:46 PM
Dim Sum's Avatar
Dim Sum
Dim Sum is offline
Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.
That thing looks nice! I'd do that in a heartbeat, but I have adaptive steering...
  #194
Old 10-13-2018, 08:22 PM
WVSD's Avatar
WVSD
WVSD is offline
WVSD is starting off with a positive reputation.
Does Jon have a PNO harness to add heat? I have a 17 Lariat, no factory heated wheel?
If is how to I reach him. I already have Boosteds harness for paddle shifters.
  #195
Old 10-14-2018, 01:28 AM
jonathanjr1
send me a pm or email [email protected]
Quick Reply: Raptor Steering Wheel Swap
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
