Early 99 starter issues
Old 04-02-2018, 08:50 AM
Jo7.3's Avatar
Jo7.3
Jo7.3 is offline
Hey guys, yesterday I had an issue with getting the truck started. When I cranked it, it cranked way slower than normal and wouldn’t start. After about 5 cranking attempts, the starter “zinged” like the bendix wasn’t engaging. It zinged twice, then fired right up like normal.
Battery voltage was 12.7 on one and 12.4 on the other with the batteries hooked up. After I got it started, battery voltage was 14 on both.
This is my 3rd starter in about 2 years, because all of my previous starters zinged/bendix didn’t engage. Granted whenever they zinged, the truck would always start eventually. When I put the 2nd starter on, I checked the flywheel and found no chipped or missing teeth. The batteries are pretty dirty, and the starter is covered in oil from a previous leak, so I plan on cleaning the batteries and starter up and seeing how it acts.
Any ideas as to why I’ve been through so many starters? The first two were from my local battery barn, and the current one is from Napa.
Old 04-02-2018, 09:03 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
#1 Clean all connections including battery grounds on engine block. #2 (Possibly #1) check that starter bolts are tight. #3 Your truck has a starter relay on passenger's side fender, apply power to the little lug on there and see if it starts any better.
Old 04-02-2018, 10:25 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
What he said...but in my experience, oil soaked will cause issues and by the sounds of it, it is happening again.
Once you get it all cleaned up and no longer drooling oil all over the starter, clean the cables and terminals and making sure you have a solid connection, replace it again. I would bet that the oil soaking may have already caused the damage.
Old 04-02-2018, 10:07 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
12.4v. is about 70% charged,I would also load test them batteries,low voltage increases amps which is hard on starters.
Old 04-03-2018, 06:19 PM
Jo7.3's Avatar
Jo7.3
Jo7.3 is offline
Thanks for the advice so far guys. I cleaned everything up today, and the truck fired right up. I will definitely be keeping an eye on how it starts though.
Old 04-04-2018, 09:08 AM
BillyBob69's Avatar
BillyBob69
Sweet! Hopefully it holds up now.
Old 04-04-2018, 09:24 AM
Walleye Hunter
I am curious as to what you cleaned and what you saw/found during the process.
Old 04-06-2018, 12:29 PM
Jo7.3's Avatar
Jo7.3
Jo7.3 is offline
All I cleaned was both batteries, battery terminals, battery cables and the wires that go to the starter. Couldn't find any loose connections, so hopefully I won't have this issue again.
Old 04-06-2018, 01:53 PM
Walleye Hunter
Ok, thanks for the follow up.
dev_jhnsn
12-12-2014 06:33 PM
DieselDrake
07-02-2012 04:11 PM
WoomaHodal
10-04-2009 08:19 PM
chucky0094
08-31-2008 08:34 PM
JD2DAWN
03-08-2004 03:32 PM
Quick Reply: Early 99 starter issues
