My 01EX Rust Removal and Refresh
  #76
Old 02-26-2019, 11:24 AM
msuser92
msuser92 is offline
msuser92 has a good reputation on FTE.msuser92 has a good reputation on FTE.msuser92 has a good reputation on FTE.
Here's the calipers after the 7 day cure and being rebuilt. The paint seemed to hold up to the rebuilding process, only a few small areas to touch up.
  #77
Old 02-27-2019, 09:00 PM
sammie0126's Avatar
sammie0126
sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
Wow, I'm an oldie who is recently back and man these pictures and this thread bring back good and bad memories from restoring an EX. Great job, Great garage, Great tools.
  #78
Old 02-27-2019, 09:30 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
feels great to drive a ex but sure does come with some heart ach forsure. m sick of replacing lift struts and door lock actuators.
  #79
Old 03-07-2019, 09:12 AM
msuser92
msuser92 is offline
When the frame was at the powder coater he called and told me he was a little worried. After the chemical wash he put it in the oven to dry and something (oil, undercoat) started seeping out of all the areas that have 2 layers of steel. We decided to go ahead and coat it and see what happened. He coated it and did not notice any more seepage. The frame has been upside down since I dropped it off to him and that is how he coated it. I have not really looked at the topside of the frame until I flipped the frame over a couple of weeks ago. The apparently was some seepage when the frame went back into the oven. I think it is the undercoating from the factory that is seeping. The are a number of spots where it ran out, so we will keep an eye on it and see what happens. I don't think (hope) it will be a problem. It looks to me like it ran out on top of the powder coating.
  #80
Old 03-07-2019, 11:31 AM
Dan V
Dan V is offline
Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.
Question.
I have a SD frame that I'd like to have either powder or epoxy. What did your research show you as far as the cost between the two? And the service life of powder vs epoxy? From what my research shows, powder can crack...and rust can start under the powder, and do a lot of damage prior to noticing.
  #81
Old 03-07-2019, 11:42 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
that would be bad if rust started under powder coating, i would watch it and paint over any cracks or peeling forsure.
  #82
Old 03-07-2019, 06:36 PM
msuser92
msuser92 is offline
Originally Posted by Dan V View Post
Question.
To be honest I didn't do any research on epoxy, or powder for that matter. I was originally going to rattle can the frame. But after the time I spent cleaning, I decided to powder coat it instead. My Father-in-law had owned a metal fabrication shop for years. He sent all of his stuff to be powder coated. He has never had a problem with powder cracking. Now granted my FIL wasn't building a truck, but some of his products take a beating. I talked to my FIL and his powder coater (which is who I used) and decided that was the best option for me. I also plan on using fluid film before winter each year, and I will be keeping an eye on it. Only time will tell.
  #83
Old 03-08-2019, 10:14 AM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.
My thinking: if you didnt remove the brackets, there will be gaps from rust between the metal parts that will hold moisture and other contaminates. These areas will continue to corrode and eventually push the powder open. The heating process was boiling the moisture out.
The contact patch of the bracket to the frame is not 100% of the surface of the bracket. Its a small percentage of extra surface around the bearing surface of the fastener. The remaining surface area is open to the elements to some degree.
  #84
Old 03-08-2019, 11:06 AM
msuser92
msuser92 is offline
The only things I didn't remove were the crossmembers and brackets that are riveted, and the area where the splice is. Coil buckets and radius arm brackets had not been installed yet.
What was seeping out was black and thick, so I don't think it was just water (moisture).
At any rate Carbon Coupe, I agree with you that there are areas that I couldn't completely clean and also that may have little to no powder. I don't know if that would change by using a different product to paint the frame. Hoping that fluid film takes care of those areas.
  #85
Old 03-14-2019, 11:00 AM
Dan V
Dan V is offline
What are your plans for all the various plastic wireloom holders, fuel line, brake lines? You know, those little fir tree push-in things.
  #86
Old 03-14-2019, 07:19 PM
msuser92
msuser92 is offline
I was able to get most of them out of the donor truck without them breaking. They are all still intact on my truck, so I think I will be OK. If not I will see what is available.
Excursion Gary
02-24-2017 07:07 AM
Nelson 2
03-24-2006 11:53 PM
magyar
1978 - 1996 Big Bronco
04-24-2002 07:47 AM
colonel_sanders
11-07-2001 09:33 PM
4dman
Paint & Bodywork
10-09-2001 08:10 PM
Quick Reply: My 01EX Rust Removal and Refresh
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
