Anyone put mud flaps on 2012 F-150 4x4 Scab?
Not a 2012 but yes, on a 2010 & a 2013. I use the FoMoCo hard plastic ones, they work pretty well for daily dirt roads, keeping step bars clear of slush & the occasional mud hole and install easily. IMHO folks more into the mud bogging sport side of things should find something more substantial. If you order some like this pay attention to whether you have "wheel lip molding" or not, it makes a difference.
thanks, if you do something like this I learned that the premade are thinner, I actually had a set break to the point of almost falling of from flapping in the wind. these are .125 inch that I had cut 12 inchs wide by whatever length I wanted on each set. It's a good idea to put something between the wheel well and aluminum to keep the diamond plate from eating through the paint and starting a rust streak. I use 1/4 inch stick on foam such as window or door seals, easy to find at hardware. make sure you tell your supplier that you want to bend them by hand, I got one set that was different grade and had a hell of a time bending them.
Robb, I am looking at the WeatherTech flaps myself for winter time use. Are they easy to take on and off??
Neil, install was a breeze though I haven't had them off since then so I can't speak to removal. I am running husky liners rear wheel well liners also and I remember there was a little interference with the rear ones, think I needed longer bolts for 1 of the mudflaps. If you don't have wheel well liners or have the Ford ones, you should be fine.
