Power outlet on dash keeps blowing a fuse even after I changed the socket!
I have a 2011 expedition. The power outlet on the dash went out .it was a blown fuse. I replaced but kept blowing when I put a load on it .I replaced the socket itself. It worked for a second but blew the fuse again. What is causing this and how do I fix it. The wires look fine at the plug. The wires then get wrapped up and go too far into the dash to follow. How can I fix this?
Sounds like a dead short. Something to do within the circuit wiring. Honestly, I would abandon that line and cap it off safely. Either trace the line (which will probably be too difficult) or run a new line dedicated for the power port using 12 gauge stranded. Its not worth the potential for fire. Make sure you rule out that phone charger first.
I tried the outlet and new power source but it blew the fuse again. Where can I look for the dead short or how do I rewire the socket itself. I just don't like having something that should work not work. The cigar lighter works and the all other power outlets work fine but the one in the dash just keeps blowing the fuse. Any videos would help greatly.
