oil pickup tube/screen for 4wd
Does anyone know about a oil pickup screen available for 360/390 for a 76 f150-I know that the Melling p/n# is 57-s3 but it is now obsolete. Don't mind paying for a new or aftermarket
piece, it is for a stock oil pan. Any help would be appreciated----thank you very much.
If you want NOS I have one. PM me for details.
Otherwise, you can run a Canton 16-871 Pickup assembly https://www.summitracing.com/parts/ctr-16-871
The NOS would be more expensive than the Canton.
I run the Canton 16-871 in my 390 stroker. My engine builder verified the clearance for it was fine.
Maddog and Jakeharp, -Thanx for your replies, I went ahead and ordered the Canton pickup tube. I did find a Pan from a small parts store that had a used one. So I was fortunate. Idid call Summit and and talked to Tech Support-they said it would not work but I went with your experience, they said if I "tweaked" it it would be ok or send it back.
I searched local and the Spokane, WA area but being that I work for O'Reilly Auto Parts part-time, I knew a local guy that has a small parts store and had some older parts and he
had 1 left and a another local small mechanic shop had a good used pick-up tube as well -Thank God. But I will keep the pickup as a stand by and use the pan w/the new pickup.
I might have a couple of friends that have some old ford ranch trucks and am going to see if I can get some parts, or buy the trucks for parts if necessary.
airrikk17
01-14-2006 11:32 PM
woodsrider505
05-02-2005 02:49 AM
Azguy54
03-04-2005 09:42 AM
