2018 F450 KR factory accessories...
The gooseneck prep package had more stuff in it than in my last SD. Also, the chain hooks spread the load over all four holes instead of 2. The swing box will need to be removed on the driver's side when hauling a gooseneck - not enough room for the brake hookup. The loading ramps add a plate on the tailgate that they hook into - really nice ramps.
I think any SD ordered with the gooseneck hitch package will get them. Apparently, this is the newer design which makes more sense. The setup I had on my '15 F450 had the two pucks only and had to be removed with a screwdriver to get them out of the bed. This setup spreads the load and you are able to remove them quickly by hand to get them out of the way. The older setup with one ball was $250 - I believe this set is around $450 from Ford accessories if not ordered with the truck.
https://accessories.ford.com/exterio...bar-11603.html
https://accessories.ford.com/exterio...eneck-kit.html
Thanks,
Chris
Christian's1988Ford
17
01-11-2023 04:57 PM
F100wish
06-18-2019 08:12 PM
76f350spercamprspeal
Vehicles for Sale
11-02-2012 09:19 PM
