Lift kit - Page 2 - Ford Truck Enthusiasts Forums
Lift kit
Old 03-21-2018, 01:01 PM
Jo7.3
Jo7.3 is offline
Jo7.3 is starting off with a positive reputation.
Originally Posted by afonda View Post
Also need a drop Pittman arm.
Should be able to find one fairly easily. Any of the major suspension companies should have one like rough country, superlift, tuff country, fabtech, bds, icon.
Old 03-21-2018, 06:56 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Good point. Since you're basically doing a lift now instead of a leveling kit, you'll need an adjustable track bar bracket too if you don't have one.
Pitman arm can be a pain to get off. Buy a puller with a lifetime warranty in case you need to exchange it. I used the big 2 prong puller for one. Had to cut the teeth down a tad to fit around the pitman arm, but that's not where the first one broke. The second one got it off. PB blaster likely helped.
Old 03-25-2018, 11:00 AM
afonda's Avatar
afonda
afonda is offline
afonda is gaining momentum as a positive member of FTE.
Longer brake lines?
Any idea on sourcing longer brake lines?
Old 03-25-2018, 11:08 AM
johnsps250
johnsps250 is offline
johnsps250 is gaining momentum as a positive member of FTE.johnsps250 is gaining momentum as a positive member of FTE.
I'm assuming you are asking about hoses for a lift. If so, try Crown Performance
Link
Old 03-25-2018, 08:09 PM
F350-6's Avatar
F350-6
F350-6 is offline
I think I got mine from 4 wheel parts. They sell a lot of lift kits and had a good price on stainless braided lines. (you just have to replace the flex line from the fitting down to the wheel).
Old 03-25-2018, 08:34 PM
00t444e's Avatar
00t444e
00t444e is offline
00t444e is gaining momentum as a positive member of FTE.
How much total lift will you have? I have a 4" on mine and I didn't need a drop pitman arm or longer brake lines, all I had to do was bend the front brake line brackets down some.
Old 03-26-2018, 06:37 PM
F350-6's Avatar
F350-6
F350-6 is offline
The idea behind the longer lines is so that the suspension can have it's full range of travel, with a safety margin, and not cause a problem. Think using a ramp to jump another car and how much your truck will bounce when it lands. Or if you jack it up by the frame and let the wheel drop all the way down.
The drop pitman arm is for geometry reasons. Less wear and tear on the steering components the closer to horizontal the linkages are.
Will it work without these? Sure. But things are going to wear out faster, and that one big pothole might lead to a brake nightmare.
Old 03-26-2018, 07:36 PM
00t444e's Avatar
00t444e
00t444e is offline
That's true but with my suspension at full drop my factory brake lines with the bracket modified are long enough, also I have been lifted for 3 years still using the stock pitman arm with no steering issues.
Old 03-27-2018, 07:35 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
You shouldn't need longer brake lines. If I recall correctly if you take one of the clamps off it will net you more then enough room to have the length that will be acceptable. I'm going off of memory here too but I don't believe I needed to have longer lines with my SD with 8" lift and 38x15.5s. I want to say I either relocated the bracket or there was enough "give" in them and that's with me actually using a lifted truck as a lifted truck including air time
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
