Early 99 7.3 No low end torque.
#32
I think there is an OBDII link in my signature that shows how to log data with FORScan. Looking at a couple of snapshots during idle and casual driving doesn't tell the story in a linear fashion. If I showed you a picture of Hansel and Gretel dropping bread crumbs, then one of them eating with a witch, then (spoiler alert) a witch in the oven - you'd say "There's a story in here somewhere, but darned if I can figure it out from these snapshots." If you log your data and share it here, it tells a story - but I need to see the dramatic stuff (WOT in gear) with the idle.
Oh... and I would shave that list of PIDs way down if you want better resolution. Our old, decrepit electronics are slow - and asking them to do a lot just means they get through the list with less zest than desired.
#33
#34
#35
So I have an update I was watching my skin or a little harder and noticed half throttle I was at 2600 psi with high-pressure oil and at wide open throttle was only getting 28 psi of exhaust back pressure and no smoke does this mean it is not getting the correct fuel? What exactly tells the truck to get it fuel I guess I’m asking which sensors or what could cause this.
#36
