It`s official....... SYNC 3 version 3.0 has been released
#31
I upgraded from 2.3 to 3.0 this morning. The screen seems a lot faster. The only "issue" I've seen is after the start up is complete, the screen tells me that Sync is able to connect to WiFi (I didn't have this happen on 2.3). I went into the General settings and then disabled the WiFi network notification.
#32
I`ve never used Waze but if you look at it this way, if they are they same, why use up the data on your phone when the SYNC system can do the same.
Both Waze and Ford/SYNC said it should be available soon.
#33
No, the owners website has never updated. I'm still showing the last update being 1.0 on Dec 15, 2015. It always shows when the latest update is available, such as the 3.0, and I have no problem installing the update. The website just will not take the confirmation. I've talked to the sync people and they don't have a clue. I put it out there because I know others have the same issue.
I`m not sure if you`ve tried this yet or if it`s possible after the fact but have you tried deleting your Ford Owner profile and just start off fresh with a new one by registering again?
I`m also not sure if it matters but are you registered with both Ford Owner and FordPass?
#34
Wow, that is very odd.
#35
#36
One of the other changes is the radio turning off if you unplug your phone after using AA or CarPlay. That was a major bug bear of mine having to turn the radio off before I unplugged or else get my eardrums blown out by the radio. Bass response seems a little better also.
All those who want to use Waze, if you have android it will run fine in AA, I use it all the time, and did with 2.3 also. CarPlay people, the news isn't so good. That is more down to Apple wanting to force you to use their maps than google/waze.
#37
I updated to 3.0 this Saturday and everything went well. After plugging the USB stick into the vehicle, total update time took 24 minutes and 5 minutes of that was waiting for the System Updating message to come up on the screen. The download to my computer and then to the USB stick took quite a bit longer than the actual update.
After receiving the Update is complete message and to remove the USB stick and that updates will take place on my next start up, I turned the vehicle off, got out and locked the doors. I waited for an hour before I started it up again.
After start up, I immediately notice a few different things on the SYNC screen.
I guess this applies to people with Sirius but the SXM logo is now on the screen, the font or style of words has changed, the navigation logo has changed, I don`t use it but the AA logo has been removed so perhaps it`ll come back up once AA is plugged into the USB upon setup, and i`m sure there is more but I haven`t checked everything.
To me, the speed seems to be the same as 2.3.
I used a Mac for the upgrade so if any Mac users are having problems just ask away and i`ll try to help you.
Have a great day.
Have a great day.
#38
#39
#41
I ended up turning off the WiFi feature since I don't use this feature on the regular.
#42
#43
#44
#45
Are you saying that the vehicle did not write the .xml file to your USB drive? When the update is successful, it will write a file on the USB drive with the vehicles VIN and will end in .xml. If the update happens over the air via wifi, it should upload the file directly to ford.
