4x4 front wheel hub assy. need help - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-18-2018, 08:40 PM
fdude64's Avatar
fdude64
fdude64 is offline
fdude64 is gaining momentum as a positive member of FTE.
Haven't been here in a long time. looked around some and haven found anything out. i am in the process of replacing both front hub assemblies. Have been on this most of the day and have got nowhere. Watched a you tube video and the guy said just wiggle it a little and it will come right out. uh huh right. i have pried and beat my brains out and it moves a little but it wont come off. yes i have the lock out off and the snap rings too along with the 4 nuts on the back. Am I missing something?
Old 03-18-2018, 09:05 PM
99f350sd
99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Nope you should be good...beat on the studs in the rear if you can... if its a little loose pry it off straight..with big pry bar.
Spray some pb blaster in the crack.. what year truck?
Old 03-18-2018, 09:18 PM
fdude64's Avatar
fdude64
fdude64 is offline
Sorry it is a 2000 f350 4x4
Old 03-18-2018, 09:36 PM
SnowPlowDriver's Avatar
SnowPlowDriver
SnowPlowDriver is offline
SnowPlowDriver is starting off with a positive reputation.
Living in the salt belt you will need a bigger hammer.You will also find your dust shields are rotted where the studs go through.
Old 03-18-2018, 09:38 PM
fdude64's Avatar
fdude64
fdude64 is offline
Feels like the o ring is fighting me
Old 03-18-2018, 11:12 PM
StrokinHer01's Avatar
StrokinHer01
StrokinHer01 is offline
StrokinHer01 is starting off with a positive reputation.
Put two screw in the hub and pull with some pliers...you can try an heat the out part of the hub housing also...
Old 03-19-2018, 11:29 AM
fdude64's Avatar
fdude64
fdude64 is offline
Build a fire under it?
Still not able to get hub bearing assy. Out
Old 03-19-2018, 11:41 AM
fdude64's Avatar
fdude64
fdude64 is offline
Doesn't help I'm workingin my driveway. No air tools and on my back
Old 03-19-2018, 12:12 PM
99f350sd
99f350sd is offline
You said it loosened a little. Can you get a chisel in the crack? Buy a cheap 1/2 extension and use the female end on the stud with a 3lb hammer. Make sure all the nuts are off lol.
Old 03-19-2018, 12:19 PM
Lawnpro979's Avatar
Lawnpro979
Lawnpro979 is offline
Lawnpro979 is starting off with a positive reputation.
Spray, push, pull, beat with a BFH, and it will come off when it wants too...
i know, that sucks, but its just the way it is.....
If you have a torch this can be a big help
Old 03-19-2018, 12:26 PM
fdude64's Avatar
fdude64
fdude64 is offline
No torches. But i do have doobies to keep my attn. on it. It will wiggle some. Out about 1/4" so far
Old 03-19-2018, 12:29 PM
Lawnpro979's Avatar
Lawnpro979
Give it a good bath in wd, or PB BLASTER, go inside, have a doobie, watch some TV.
Do the wife, then go back and see it it will help.....
if it doesnt, it didnt hurt.......
Old 03-19-2018, 12:32 PM
fdude64's Avatar
fdude64
fdude64 is offline
Bathed in pb blaster and waiting
Old 03-19-2018, 12:33 PM
Lawnpro979's Avatar
Lawnpro979
I just did mine, I know what your goin through.....
its a hard day.....
Old 03-19-2018, 12:36 PM
fdude64's Avatar
fdude64
fdude64 is offline
Started on it yesterday noon.
Quick Reply: 4x4 front wheel hub assy. need help
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
