Tried to add cruise control but need help - Ford Truck Enthusiasts Forums
Old 03-17-2018, 08:32 PM
landon1986
landon1986 is offline
landon1986 is starting off with a positive reputation.
Hey guys,
I've got a 1996 Ford F-250 that came from the factory without cruise control. I did some research and found that adding factory cruise to one of these trucks isn't terribly difficult. I found a junk truck with cruise, so I took the steering wheel cover, servo and cable. I bought a new brake master cylinder for a truck with cruise along with a new brake sensor. After installing all of these parts, the cruise still doesn't work. Is there something I've missed? As always, many thanks for the help and suggestions!
Old 03-17-2018, 08:46 PM
wtroger
wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
Did you get the clock spring the supports cruise control for your truck.
Old 03-18-2018, 11:46 AM
landon1986
I apologize, but I'm not exactly what you are referring to. Where are the clock springs located and what do they do? Also, is there any light or indication that the cruise is on (ex: "cruise" light on in dash)??
Old 03-18-2018, 05:39 PM
wtroger
wtroger is offline
it is a device behind the steering wheel that provides connectivity to the switches and air bag housed in the steering columne
Old 03-18-2018, 08:56 PM
landon1986
On these trucks, is there any light in the dash or indication that the cruise is ON? Also, are clock springs difficult to change? Thank you
Old 03-18-2018, 09:27 PM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
No on or off light on dash.
They are not that hard but the steering wheel on that year has an air bag in it so you should disconnect the battery an hour before working with it or it may explode.
Old 03-18-2018, 09:49 PM
landon1986
My truck doesnít have an air bag on it. It is the XL package, so maybe it didnít come with it. Iím wondering if that makes a difference on the clock springs. I removed the cruise parts from a donor truck that also didnít have an air bag. What are your thoughts?
Old 03-18-2018, 09:56 PM
subford's Avatar
subford
subford is offline
What year truck did you get the steering wheel from that you are putting on the 1996?
Old 03-18-2018, 10:30 PM
wtroger
wtroger is offline
There has to be away for the steering wheel switches to get there signal to the control module it is either a clock spring, or old style sliders either way something is attached to the steering column.
Old 03-18-2018, 11:11 PM
Bluediesel250
Bluediesel250 is offline
Bluediesel250 is starting off with a positive reputation.
Subford I think you might have missed that it's an f250. As far as I know only the f150s had airbags installed that year
Old 03-19-2018, 07:10 AM
subford's Avatar
subford
subford is offline
My 1996 Ford shop manual says that the 1996 F-150, F250 and the Bronco had air bag systems that year.
That is all I have to go on for that year is the Ford Shop Manuals.
Old 03-19-2018, 11:11 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Light Duty F250 is probably what they are referring to.
Old 03-19-2018, 01:17 PM
rmcline4
rmcline4 is offline
rmcline4 is starting off with a positive reputation.
Isn't there a vacuum switch on brake pedal?
Old 03-19-2018, 01:38 PM
rla2005's Avatar
rla2005
1993 and later F-series/Bronco have the electronic Speed Control system. No reservoirs, actuators, valves, etc.are used.
Old 03-21-2018, 08:46 PM
landon1986
After doing some double checking, my truck is a 1997 F250 HD old body style. I promise there are no air bags. I took the steering wheel cover off of an F350 with cruise and no air bag. I am going to check to make sure I have everything plugged in and make sure a fuse isnít blown. Iím guessing my truck doesnít have a clock spring since there is no air bag?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
