does the column shifted 3 speed share the same bolt pattern as a NP435 or T19? i read online that a NP435 fits small block style bellhousings and thats great and all but i cant find any info on the 3 speed. I believe they are T-85s? im still rocking the 360 FE.
The Ford 3.03 3 speed trans uses the same butterfly bolt pattern as the NP-435 and the BW T-18. So every bell housing pattern (Small block Ford/Big Six, FE) can be used.
