ebpv pedestal rebuild? or buy new??
I have always wondered if this was good or bad as "everyone" says that having a large difference between boost and exhaust back pressure is bad. How much exhaust back pressure do you normally see when using it as a brake? It is something I always wanted to do but never did. Not saying it is bad to do as many do and have done for years but it does seem to go against the boost ebp delta is bad statement
Of course the 99-03 model design are a bit different but the concept is the same.. .
Jody wrote the tune BUT, i stand corrected . spoke with jody today and he informed me the the ebpv does not do anything in his tow tune. Not sure where i heard that it did. all he uses is the torque converter and coast clutch in the tune to help slow the truck down . sorry for the mis-information. Hey cleatus, i know your are a genius on the trucks and was wondering what you thought about wiring the wastegate shut? spoke to jody and he told me that i should be seeing 28- 30 psi boost with his tune, and im only getting 25 psi. he told me to wire the wastegate closed, so i tried it and i do notice a difference. Do you think that may be harmful ? still only seeing 26 psi so i may have a small leak somewhere that is impossible to find. i am about to rebuild my turbo with sp turbo kit, and was going to put on a turbo master wastegate( already bought it), but jody said to wire it shut and call it a day. i sometimes get a p0476 code which is basically saying that the ebpv isn't operating correct during KOER. So i just bought a whole new ebpv instead of rebuild kit . At least i can rule that out and not worry about it. Jeff at deisel o rings said i don't need to set the tension on a new ebpv. hope he is right.....
Orezona
50
12-30-2007 07:27 PM
