Roof repair 56 F100 Help Please.. - Ford Truck Enthusiasts Forums
Old 03-16-2018, 08:00 AM
Greg Rogers's Avatar
Greg Rogers
Greg Rogers is offline
Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.
Wow I didn't realize how bad the roof was until I finished the bottom of the cab and set it on floor. Basically the entire roof skin is detached from the drip rail. I really don't want to fix this now, but need to do something. If I drive this thing as is I could see air flow bending it up and really making a mess. I'm afraid it is too much for self leveling RV type sealer, which is what I thought I would do earlier. I'm afraid to take a wire wheel to it as I think it would go inches up in the top with nothing left to attach to. What do you guys think?
. Thanks for your input/ advice, Greg.
Old 03-16-2018, 08:30 AM
clintonvillian
clintonvillian is offline
clintonvillian has a great reputation on FTE.clintonvillian has a great reputation on FTE.clintonvillian has a great reputation on FTE.clintonvillian has a great reputation on FTE.clintonvillian has a great reputation on FTE.
X brace the cab, and order a new roof and drip rails. Expensive, but worth it.............I didn't, and I have WEEKS invested in mine.....
If you need any more info, check out my threads.
Old 03-16-2018, 08:59 AM
clintonvillian
There is a section of the roof, there is the inner structure, then the J shaped driprail, and finally the cab roof comes over it and is spot welded with a bazillion spots all around. Along the back you need to use a seam buster to break them loose.
Here's how I did mine:
Old 03-16-2018, 08:31 PM
Effies 56
Effies 56 is offline
Effies 56 has a very good reputation on FTE.Effies 56 has a very good reputation on FTE.Effies 56 has a very good reputation on FTE.Effies 56 has a very good reputation on FTE.
Greg,
That roof project is not going to be easy. New or repair looks like a project either way. Maybe find a donor roof in better condition?
Regards,
Chris
Old 03-16-2018, 09:36 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
I know you said you really don't want to fix it now, but any temporary patchwork you do will make a proper repair later that much harder. Personally, as big of a pita it will be to do, I'd say it's better to do it now than wait 'til later. You won't regret the decision.
Old 03-17-2018, 08:11 AM
Greg Rogers
Yeah I know what you mean. Just spent about $1000. plus lots of labor on the bottom, Yikes! The reason I thought about just a cobble for now, is that the 56 "soffit" isn't yet available but may be soon. I was thinking of making the truck driveable then going back with all new roof, drip rail, and soffit at a later date, Actually I may eliminate the drip rails- I don't know..... This truck is not going to get painted, at least not yet.
Old 03-17-2018, 08:13 AM
Greg Rogers
Originally Posted by Effies 56 View Post
Greg,
Regards,
Chris
Yep, a better roof would be great but fat chance of that around here! I'm looking!!
Old 03-17-2018, 08:45 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
I ran into this problem with my 56. After two donor roofs and my cab in the shop for 15 months, I wish I’d have done two things. First fixed the roof first and 2nd bought a new steel (or fiber glass) roof.
What’s your plans for your truck? If RestoMod you could remove the drip rails. There are several here on FTE that have done that.
Old 03-17-2018, 09:47 AM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is online now
bigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant future
I just bought this cab and doors
They are out there you just have to look. The money spent for a cab and doors like this is money well spent.
Old 03-17-2018, 09:54 AM
Greg Rogers
The idea of the truck originally was going to be a old usable truck that a kid would have got running in the 80's or so. " Dad gave me this old truck with a bad engine, so I'm going to put a 300 six in it and use it". Not really a "Rat Rod" that is made to look bad but just a old truck that looks like it is, complete with bad paint. etc. But floor was swiss cheese and corners were bad and I fell into the MAW trap. Now bottom of cab is done and I have too much involved in it to quit now. I guess it is more CQN ( cant quit now) rather than MAW. By the way, How is your wife doing, BJ?
Old 03-17-2018, 10:13 AM
bjmayberry2
Greg, Thanks for asking. She just got her two month CT Scan. Well get the results Monday. She has her good & bad days but in general shes doing pretty good.
Your dilemmais pretty common, thus the recommendation to do the roof first. Not sure what BigWin56f100 wants for the cab but its very easy to get several thousand wrapped up in the repair of a bad cab and doors.
Old 03-17-2018, 10:21 AM
56panelford's Avatar
56panelford
56panelford is online now
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Your Delia is pretty common, thus the recommendation to do the roof first. Not sure what BigWin56f100 wants for the cab but its very easy to get several thousand wrapped up in the repair of a bad cab and doors.
It wouldn't be cheap BJ
Old 03-17-2018, 10:28 AM
bjmayberry2
Some times the saying is true; “If you wanna play ya gotta pay”.
Old 03-17-2018, 10:30 AM
56panelford
Posting Legend
There are cheaper ways..
Old 03-17-2018, 11:10 AM
bigwin56f100
nice 56 cabs and doors are never cheap. Costs me a small fortune to get and sometimes when I get it it's no where near as nice as it was expected to be. Nice 56 cabs are few and far between.
for the people who have to pay for panel replacements in parts and labor, a rust free expensive cab is in their best interest to move the project along in a quicker fashion
Quick Reply: Roof repair 56 F100 Help Please..
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
