Emergency Break away Brake
I was curious if I could use my emergency break away break to set my breaks when parked for additional security,,just pull the tab out and the breaks set on my car trailer. The current is supplied by a large vehicle battery. Would this damage the magnets or wear the battery down quickly? I appreciate all input on my question.
Thanks ,Ron
Thanks ,Ron
Gotcha. When you first said "security" I was thinking in terms of the trailer rolling away down a hill, or something along those lines. FWIW, electric trailer brakes pull right at 3 amps per wheel, so a typical tandem trailer would have a constant 12 amp draw with the pin pulled. If you ever DO intentionally pull the pin, unplug the umbilical cord first. Some brake control units don't like to be back-fed and will get fried when you pull the pin, if you don't unplug first.
Received 6,656 Likes
on
as stated..
do not... for many reasons..
one being.. battery will only last maybe half hour... then trailer could just roll away...
might burn up wires.. not for long use... magnets will overheat.. again not for 100 percent use...
it is NOT a cable system... but a battery, switch, magnet...
and without trailer moving.. no REAL braking is done... as magnet MUST rotate with Drum.. no wheel movement,,, no brake applied..
as stated..
If you are looking to stop some of the movement while parked they make a devise that goes in between the tires and will keep them from rolling.
this is what I use for Parking trailer
Homemade RV Wheel Chocks | LoveToKnow
homemade .... harbor freight pipe clamp.. pipe.. and wood.
