Loud knocking 7.3
Loud knocking 7.3
[left]Okay so I bought a 7.3 a week ago and never noticed this knock until after my fuel filter light came on so I checked the filter looked brand new but lots of sand in the fuel bowl cleaned it out then noticed a knock almost sounds like rod knock. Did a buzz test all sounds good did a contribution test it passed. I’m at about wits end with this truck.
https://youtu.be/Qem5Q-OFQLI
I had a similar problem with mine. Had a weak fuel pump with a leak causing low fuel pressure causing fuel knock. Wound up rebuilding fuel bowl assembly while I was replacing the pump and that made all the difference. Like farmert says, any time you get water in fuel light you should replace filter.
filadog23c
11-06-2019 10:45 AM
dkrahn
05-26-2007 09:04 PM
