Best Aftermaket Western Junior Mirrors?
Looking for some junior westcoasts for my 9th gen F250. I plan on only using the truck for hauling and it came with the plastic sideview mirrors, and would like to go with either junior westcoast style or the metal frame style that came from the factory.
Pic of what I mean by the factory metal frame style:
Are there any aftermarket brands for side mirrors people recommend? I don't want something that shakes or will be push-adjusted by wind speeds. Or are OEM ones from a junkyard my best bet?
I'd get yourself some of these bad boys. I have them on my f350 and love them https://www.summitracing.com/parts/ksc-h3551
From what I have seen/read, their are no good aftermarket mirror for theses trucks, it seems like they all shake pretty bad.
I have the ones in the picture on my 97 and I love them when I'm not towing, But they seem a little small if I'm towing any type of enclosed trailer. I also have the one's that InsanePyro linked on our 93 and I love them.
But both of these are factory mirrors, I'll never get aftermarket for these trucks.
I think the ones on your 97 will do the job just fine. I had them on my 87 and I've towed with my buddies 97 F250 that had them and they worked. I think that's the route I'm going to go in the end. I'm sure I can find some at my local yard, they have a huge truck section in the boonies. Thanks guys.
I'll only ever be towing single car open trailers, so I don't need anything that sticks out crazy far, but I do think a smaller west coast mirror looks pretty cool.
Another thing to keep in mind is that I believe the plastic paddle/sport mirrors on your truck have a wider mounting plate then the "swing-away" mirrors on my truck. So you may have an exposed hole that will need to be covered up/filled if you make the switch.
EDIT:
The bolt pattern is different
The western swing a ways are 3-3/4" and the rearmost bolt is 24-15/16 from the rear edge of the door
The sport paddle mirror are a 5-3/4" and the rearmost bolt is 24" from the rear edge of the door
So if you see what I am saying, you would have an exposed hole left over from the front sport paddle mirror
AND where the front mirror hole is on the western mirror is a 1" square hole from the sport paddle mirror so you have no place to put the front bolt
Maybe I will go for those. They do look a little more fitting than the west coast style on a newer, 9th gen truck, as opposed to like a 7th gen or something. They just look a little extreme with the tripod design and may look out of place on my extended cab long bed 250. But I will consider. Is the quality of those summit units good?
250-highboy-76
18
04-24-2006 06:34 PM
