What did you do to your F150 today?
#151
Friday afternoon, my F150 was taken to the dealer on the rear of a flat bed tow truck. Wife was coming home from our son's house. Driving up a hill on a hilly 2 lane country road, it suddenly dropped down into limp mode. Speed went down to about 5 or so miles an hour. Luckily was able to nurse it up the hill, and over to a parking area. The wrench came on at the same time.
I was at the doctor's office when it happened. After getting to where she was, about an hour later, I tried starting the truck. Started right up, and no wrench was showing. The tow truck had already been called so we sent it to the dealer to find out what is wrong.
#152
#153
#157
I used the product AE000 which was for a 2019. It has the auto stop button and hazard light button on the same switch. It took about 10 minutes to install, but you have to be agile to get behind the dash to push the clips on either side of the switch so you can pull the switch out and work on it. To access the back of the switch, lift the rubber mat on the dash tray and undo the two 7mm bolts on the tray. Then lift up. There are three "clips" that hold the tray as well as the two 7mm bolts. Just lift straight up and they will come undone.
#158
#159
#165
