Finally registered on here cause off all the help I get. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Truck Enthusiasts Site Navigation > New Member Introductions
Reload this Page >
Old 03-14-2018, 12:57 AM
ScumFord
ScumFord is offline
ScumFord is starting off with a positive reputation.
2000 f250 5.4 vin letter L 229,xxx miles 2wd. Problem. Low idol under load. Truck was given to me not running and 2 flat tires. Misfire cyl 5. TB completely coated in grim. Dirty MAF. Clogged cat. Deteriorated muffler. IAC snorkel hose loose. Pvc not connected.
I now have the truck running. Put Toto M/Ts 33s. New plugs ( ngks ) -cyl 7 plug soaked in oil.- new coil pack cyl 5. Removal of cat. Cleaned TB and seafoamed thru booster, oil, & fuel. Cleaned mass (even replaced with another used cleaned one.
Idol is still low under load (500-700 rpm). No code light on as of right now. But did get a p0141 bank 1 #2. So the trucks running Ritch and rough idol. Where should I start next?
Thanks for all the help
Old 03-14-2018, 09:01 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold
Welcome to the forum and we hope you enjoy your time here. We have a great group to answer questions and help with problems. We look forwards to your questions and input.
Look in your states chapter and talk with your neighbors.
Rod
landshark99
04-05-2013 07:59 PM
CommercialRig
09-10-2009 08:47 AM
DougF
10-17-2005 08:00 PM
Ole Gray
08-19-2005 11:47 PM
bilter
04-15-2005 03:16 PM
Quick Reply: Finally registered on here cause off all the help I get.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
