67 f700 352v8 holley carb info
It should have two idle mixture screws under the float bowl. An idle speed screw on the left side linkage. To adjust the float level remove the plug on the right side of the bowl. The jam nut and screw on top are used to adjust fuel level to the bottom of the hole at idle. Those are your simple adjustments.
1967 F700 361 2V FT engine with Holley 2V
You have an F700 with a 361 2V FT engine.
Carb ID number: C7TF-9510-AD = Ford part number: C4TZ-9510-T replaced by: D2HZ-9510-J .. Holley 2V Carburetor (Motorcraft CA-793-A) / Obsolete
cooperstown24
02-14-2019 04:09 PM
blue76
16
09-01-2016 09:03 PM
packrat56
26
02-08-2016 03:25 PM
scramboleer
03-20-2013 12:29 PM
