C6 rebuild question - Ford Truck Enthusiasts Forums
C6 rebuild question
Old 03-13-2018, 08:02 PM
Russ74
Russ74 is offline
Russ74 is starting off with a positive reputation.
C6 rebuild question
So I got my C6 torn down. The pic is from the forward clutch. I donít see any material on the frictions. Nothing like what was in the other clutches. They looked pretty good considering their age. Anybody think these frictions could be the cause of my transmission slipping?
Old 03-13-2018, 08:22 PM
1TonBasecamp
1TonBasecamp is offline
1TonBasecamp is gaining momentum as a positive member of FTE.
Interested in hearing what the experts say. I would have expected to see at least sections/pads of a different friction material, but I have no experience with C6 transmissions anyway, so don't know what I'm talking about.
But happy to learn new stuff!
As a total non-expert though, they look pretty worn to me.
What year is the trans? Was it using Type-F or Dextron fluid?
Paul
Old 03-13-2018, 08:29 PM
Russ74
Russ74 is offline
Itís in a 74 F100. I was just told by an expert that those frictions actually do still have material on them. I was comparing them to frictions in the other clutches which have a waffle pattern on them. I was informed that these frictions in the forward clutch have a smooth pattern. Either way, theyíre all being replaced.
Old 03-13-2018, 08:54 PM
1TonBasecamp
Sounds like a plan.
Make sure to find out which fluid type that the clutch manufacturer recommends. Even Ford went to Dextron in later years (my '79 takes Dextron) and many clutch manufacturers prefer the type of material that happens to like the GM-spec stuff.
Maybe you know that already. Thought I'd bring it up just in case.
Paul
Old 03-14-2018, 01:21 AM
black & blue 78/9
black & blue 78/9 is offline
black & blue 78/9 is starting off with a positive reputation.
Russ74....What brand did you choose to use for your C6 rebuild? WHy did your pick them? Thanks
scotttahoe
24
09-27-2015 04:39 PM
bamaf150
06-03-2010 06:04 PM
thebigunitmjb
05-01-2003 05:46 PM
mnfordcowgirl
16
01-17-2003 01:59 PM
jml
12-30-2002 06:53 AM
Quick Reply: C6 rebuild question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
