CEL, HPOP pressure, and boost...have some questions - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Reload this Page >
Old 03-13-2018, 07:24 PM
Hit Man X's Avatar
Hit Man X
Hit Man X is offline
Hit Man X is gaining momentum as a positive member of FTE.
Thumbs up CEL, HPOP pressure, and boost...have some questions
So finally got my old Edge Insight CS working on the 7.3 and had time to check numbers.
On my tow and hot street tunes (I am on stock injectors still to best of my knowledge), HPOP pressure showed 1500psi at WOT and IPR 61% around 3000rpm...to me it seems like I am in need of a new HPOP. It will hit 2600psi, then drop pretty quick. The ICP sensor leaks, so I am going to change that sooner than later to verify I am not receiving false readings. Can leaking injector orings cause a drop in HPOP pressure also? I have about 550psi hot idle and 11%.
I also found I had four CELs and one was lit in the dash by this testing:
P0238 - Overboosted around 25psi on street mode?
P0236 - Same as above
P0603 - due to the ECU's chip
P1211 - Low HPOP pressure
Do my findings for the codes sound okay? I am not too concerned about boost as my uppipes leak, but I was surprised to pass 25psi.
Thanks guys
Old 03-13-2018, 11:58 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
The first two codes I just ignore. The 1211 can be a nightmare, I can still get it with stage I's in a hot tune. I use the adrenaline hpop from dieselsite and feel that its a 'touch' better then the T500. Hope I'm not starting an argument. Yes, it looks like you need a better hpop.
Old 03-14-2018, 07:36 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Swap that ;leaking ICP first before you worry about the HPOP. And yes, if your injector o-rings are leaking, that can most certainly contribute to low HPO pressures. 1600 psi is low, for sure, which is probably why it's setting the 1211 code. As Glenn said, the other codes can just be ignored.
Old 03-14-2018, 08:58 AM
Talyn's Avatar
Talyn
Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
The 15 degree HPOP's rarely fail. That's why the modified 17's are rebuilt to be like the 15 degree ones.
You're getting bad readings from the ICP which is giving your motor bad idea's on the IPR rate.
Drive the truck with the ICP sensor unplugged and I bet you'll see way different IPR numbers. 61% on stock injectors is a bit on the crazy side. hahaha.
Old 03-14-2018, 11:36 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Okay cool guys. I will start with the ICP and retest. Then do injector orings, I am leaning toward doing new sealant on the cups while in there so I can use ELC coolant instead of dicking with the SCAs.
Thanks again
Old 03-14-2018, 12:55 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
knottyrope has a good reputation on FTE.knottyrope has a good reputation on FTE.knottyrope has a good reputation on FTE.
also test GPs while in there and maybe do IPR orings
Old 03-15-2018, 09:45 AM
Talyn's Avatar
Talyn
Talyn is offline
Thanks again
dont mess with cups unless you absolutely have to.
These are in the realm of "aint broke dont fix it" territory.
Old 03-15-2018, 10:29 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Good to know, I will continue with SCA tests then as needed.
Just did HPOP lines, I just did not trust the factory ones anymore. One less failure point.
PS, this Fluidampr really makes this ol' 7.3 smooth even at 3200rpm.
Old 03-16-2018, 02:40 PM
Hussler's Avatar
Hussler
Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
I've read on here the Fluidampr is a really great upgrade. Never tried it but seems your experience is confirming that fact.
Old 03-17-2018, 03:37 PM
Action4478
Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Without the ICP sensor , the PCM will have to assume ICP . 61 % is what the PCM is calling for .The IPR does not report to the PCM . ICP pressure is what is reported . He may just need an IPR O ring . THe small one
Old 03-17-2018, 03:39 PM
Action4478
Double post
BolognaBlake
03-23-2018 09:19 AM
Boost240sx
11-26-2015 04:35 PM
Roadhunter
05-26-2011 04:51 PM
brian42
16
12-21-2009 07:28 PM
MagKarl
17
07-29-2007 10:38 AM
Quick Reply: CEL, HPOP pressure, and boost...have some questions
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
