1966 Ford F-350 - Page 3 - Ford Truck Enthusiasts Forums
1966 Ford F-350
Old 03-18-2018, 10:11 AM
tripleframe's Avatar
tripleframe is offline
tripleframe is gaining momentum as a positive member of FTE.tripleframe is gaining momentum as a positive member of FTE.
Originally Posted by Daves1966 View Post
Hi guys,
Just wanted to make an official first post. I just picked up this 1966 F350 yesterday. . Rear end has been swapped to single wheel with 3.33 gear, 8 bolt pattern, front and rear.
As you already know, the F 350 originally has a straight front axle with 6 lug hubs, what makes the swap to 8 bolt easier, is the F 350 front drums are already 8 lug behind the 6 lug adapter. This works out well for single wheels. but dually type front wheels would have a clearance issue..
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
