Trailer brake issues
I have a 2016 f450 6.7 and I lost trailer brakes today I have power to everything but the brakes I have check all fuses under the hood and in the cab. The truck doesn't have a trailer brake module that is visible guess it's built. I did have trailer brakes yesterday. I been use a meter to check the plug and fuses but just can't figure out why I don't have power to the trailer brakes. What am I missing
everthing works coming out the plug only lost the middle pin for the trailer brakes I did pull the plug apart to make sure the wire was still hooked up. At first I thought I blew a fuse but check every fuse that had to do with the trailer and all good I did check the plug that hooks to brake in the cab and all seem good I didn't know if there is a inline fuse mybe
there is no manual brake module and the dash never said anything about tailer being discounted I took my meter and check the pins on the truck without the trailer and got nothing from the trailer brake pin everything else works turn signals running lights and brake lights I hook the trail to another truck and the brakes fine on that. I'm going to dig deeper tomorrow and make sure I have power to the trailer brake fuse not sure what less to do then start there
no slider any where but I had trailers brakes two days ago i have a pito hitch and never had the trailer smack the hitch like it did today so that's why I started to check things out. It's the only truck I have that doesn't have a slide control the other 350 do but not on the 450
Well I think that is the issue and reason for no trailer brakes.
To confirm with a trailer hooked up you should be able to scroll through the screens and see the trailer settings.
if there is nothing there then you need to purchase a TBC. They are plug and play but you would need someone to activate it in the pcm
