Hazard warning quitted
hello,
Last weekend was not the best weekend for my truck, auto gearbox quitted, brake lights quitted, and the hazard warning as well, the second time even.
I had it repaired, the hazard warning, even I didn't know how, it sort of just started working again when I was goiing through the regular flasher and fuses.
beeing a '89 F-350 my hazard warning is at the pass.side under the glovebox.
any advise is well appreciated.
ps it might have something to do with the brakelights, they stopped working as well.
Received 3,102 Likes
on
i would replace the flasher .they do not last forever.
and if you have LED lights on the truck, you need a special flasher for LED lights.
i read the post where the trans dumped all its fluid, but was not able to respond at the time.
what happened to it?
if the breather vent is clogged by a big, that will cause the trans to pump itself out.
so the trans may still be good and just have a plugged vent.
mkohut
16
06-08-2018 09:36 AM
jbullfrog
1999 to 2016 Super Duty
17
01-12-2018 10:10 AM
Yougotthehit
29
02-21-2010 06:39 PM
arjr111
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
03-14-2009 10:37 AM
