1972 F100 4x2 manual steering shaft removal - Ford Truck Enthusiasts Forums
Old 03-13-2018, 10:16 AM
bmwcarl's Avatar
bmwcarl
bmwcarl is offline
bmwcarl is starting off with a positive reputation.
Whats involved with removing the steering shaft from the steering column on my truck? One side of the rag joint is permanently fused to the splined end of the shaft and I need to remove it to put a u joint on for my crown vic front end swap. I'm thinking it may be easier at this point to replace the shaft with a new one but need to get the old one out first. Any tips or tricks from the knowledge base?
Thanks
Old 03-13-2018, 04:16 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1972 F100 2WD
Originally Posted by bmwcarl View Post
What's involved with removing the 3524 steering shaft from the steering column on my truck?
Click on pic twice to enlarge it, then use the cursor to move it around.
Old 03-14-2018, 05:17 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
Do you have the engine out, or is it in?
Old 03-14-2018, 10:00 AM
bmwcarl's Avatar
bmwcarl
bmwcarl is offline
Engine is out, as is pretty much everything else in the front end so its wide open. Steering box is off, too.
Old 03-15-2018, 03:46 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
Wow, then you have it made. From the engine compart, take the rag joint off of the column. Then go inside of the cab. Unplug the Neutral Safety Switch (NSS) remove the NSS from the column The turn signal wire connector is there also- unplug it too). If you are upgrading to a newer column, you may have to replace the rubber boot on the firewall. If so, now is the time to remove the 4 sheet metal screws holding the boot onto the firewall. IF not, remove the two bolts that mount the column (from the underneath side) to the dash. Now it should be free.
Old 03-15-2018, 10:02 AM
bmwcarl's Avatar
bmwcarl
bmwcarl is offline
Thanks!! I'm not planning on upgrading the column, just want to clean the shaft up and replace the rag joint with u joint from Borgeson.
joe7865
08-02-2018 12:46 PM
coyotedave
New Member Introductions
05-31-2017 08:53 AM
51M1
36
10-14-2014 10:09 PM
vze2c2gb
09-21-2014 03:47 PM
mlf72f250
12-18-2002 11:12 AM
Quick Reply: 1972 F100 4x2 manual steering shaft removal
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
