2002 Ford Explorer Misfire and multiple codes
Old Mar 13, 2018 | 10:01 AM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
A couple worker of mine has an 02 explorer with the 4.0. he recently had the intake manifold gasket replaced as it had a pretty big intake manifold leak. He then ran through emissions and passed.
Yesterday, his check gauges light came on and the engine was shaking pretty violently. I couldn't do anything for him as he lives on the opposite side of the valley from me. So I brought one of my code readers into work and on break, we read them. There are 6:
PO171
PO174
PO300
PO304
PO305
PO316
The only thing he did yesterday after work was drive home and took it to a car wash. Not sure if maybe water got into one or a couple of the boots for the coils. Seems unlikely though. I've only ever seen an issue with washing a car on distributor engines.
Anybody have any ideas where to start? 2 of the codes are specific cylinder misfire codes, the others are random cylinder misfire and misfire on startup. I am doubting that the multiple coils just failed at the same time.
Old Mar 13, 2018 | 06:17 PM
steve(ill)'s Avatar
steve(ill)
171 and 174 are lean codes on BOTH banks... normally that means vacuum leak on a hose common to both sides, or intake gasket leaking.......
300 and 316 are random misfire codes..... 304 and 305 are misfire on #4 and #5 cylinders.. I don't think you have multiple coils, I think you have one coil ( or 2) for all 6 cylinders.. Could be one coil or could be crank position sensor, etc. Hard to tell from here, but coil could be a good bet.... Maybe water got in an electrical plug / power to the coil ?
Old Mar 13, 2018 | 06:19 PM
steve(ill)'s Avatar
steve(ill)
Old Mar 15, 2018 | 08:55 PM
shorod's Avatar
shorod
I'm also leaning toward the vacuum leak as it could explain all 6 codes. In addition to the intake manifold gaskets as a common issue, I'll also mention the PCV elbow as another common source for a vacuum leak common to both cylinder banks.
-Rod
sethrich89
1997 - 2003 F150
Jul 23, 2017 11:14 AM
bluecobra
1997 - 2003 F150
Aug 13, 2012 08:15 PM
This used to be fun!
1997 - 2003 F150
Jan 2, 2011 05:11 PM
psu152
May 26, 2009 05:03 PM
mds79
Oct 6, 2008 12:02 AM
