what is this fixture in the bed of my F350
Some load management item? It must have been part of a package I guess I ordered because I didn’t intentionally order it ( especially since I don’t know what it is)
key on the key fob slightly opens it but I can’t see its purpose. Sorry, I’ve only had the truck for about 16 days now and still getting acquainted but feel stupid not knowing something I didn’t know I had ordered.
Tie down points to secure cargo.... I am pretty sure that they come "standard" in all Super Duty Packages. Typically the dealer leaves them in a package inside of the truck and then you would install them.
Key will unlock it so that you can remove them. In my opinion, if you live in a snow & salted area, it be a good idea to remove them when not in use!
These are officially called "Box Link" in Ford speak...just tie down points as others mentioned. They are standard on a certain level XLT and higher. There are two silver keys, probably in your glovebox, that unlock these and allow removal. Once removed, the mounts can be used for e-track cargo accessories. These are definitely useful for tying things down.
Ford made a big deal about these things when the 2015 F-150 came out. I fail to see anything that special about them. I appreciate having the additional tie down points, but that is really all they do. I actually wish there was an additional tie-down in the center of the bed, especially if you have an 8-foot bed.
What’s the weight capacity of these tie downs? Unless there are substantial backing plates connected to the frame, I’m guessing these are only good for securing luggage and the occasional box of stuff. Not seeing how these can be used to tie down items that use a decent amount of cargo capacity like full 55gal drums or similar heavy items these trucks are designed to carry.
im assuming you ordered your rigs box to be sprayed with Line-X but I see the bed bolts weren’t and rightfully so. What you my not be aware of is once those bolts are removed, Ford recommendations are, to replace with new. Do you know or care if this was done. Just food for thought.
Larry,
