Hose clamps?? I got the worm ones they make me nervous the hoses are hard to get off the barbs but they don’t tighten very well.. does the trans put out a lot of psi
Be VERY careful with any thread sealant! If any gets into the cooler line it will find it's way into the trans where it can stick a valve and cause a transmission failure.
I ended up using only Teflon tape as recommended by company.. so it got it hooked up and went for a test drive all uphill for about 7-10 miles and this is what I ended up with
. This is as hot as it got. Never dropped below 150 even coasting.. thought these were 180 thermos...
Also this is what it looked like out of the package.. looks like some grease on the edge of the round parts... an does the thermostat on the inside supposed to be open that much??
Ok, the thermostat starts to open at 160* and is fully open at 180*. It always allows 10% of the fluid through regardless of the temperature of the fluid. The other thing to keep in mind is the outside temperature cold air is going to cool better than warm or hot air. You're in the mid 160* so that an improvement. Why would it drop below 150*? Theres 18 quarts of fluid, once it hot it doesn't cool instantly.
Ah I was thinking it’d stay at 180 but I saw the Knick marks and what looked like grease.. wasn’t sure if it was a defective part someone had and returned then shipped to me.. ok so 150 is a good temp to rub at as far as condensation issues. Thanks for the help fellas wouldn’t have got this far without any of it..
My gage sensor is in the test port and reads 10-15F less than truck (PID).
The ATF in the cooler line is hotter than the temperature in the transmission. The thermostat operates on the temperature in the cooler line. It seems to me that everything is working as it should.
