Crown Vic steering question - whats the joint/fitting called?
I'm getting ready to purchase the steering joints for my crown vic suspension swap into my 72 F100. The crown vic steering rack has a unique looking fitting. Is that whats called the 3/4" Ford V? And is the stock fitting on the F100 steering column a 3/4" 36 spline?
Thanks
Thanks
The Crown Vic side is a Mustang V 3/4in, the steering shaft after you the cut off the rag joint should be a 36 spline. It is always best to count half the splines and double it then you can confirm the 36 spline count.
I used the following on my build.
Borgeson 014955 3/4 DD to 3/4 Mustang V
Borgeson 013499 3/4 36 spline to 3/4 DD
Borgeson 409436 3/4 DD 36" steering shaft
D
D
D
D
D
D
D
ok cool I will keep that in mind for my build. To your knowledge do you think I would be able to get away with using the stuff off the crown Vic and save a few bucks. I have the whole car
CharlaineC
18
10-22-2014 05:27 PM
Old F1
03-13-2010 10:29 AM
cool 48
01-23-2008 08:09 AM
raydioed
03-20-2004 07:13 PM
