Need help with codes
Old 03-11-2018, 11:34 AM
josiewales's Avatar
josiewales
josiewales is offline
This is for a '88 F250 5.0L 5spd 4x4 with 208K (I think).
I had an intermittent CHECK ENGINE light on the last 300 mile trip, so read the codes.
KOEO: 56, 67, 85, 91, 92, 94, 93, 99, 81.
Truck seems to start and run good, but I want to fix before having to walk.
56 appears to be MAF, so I'll clean it before further work.
67 seems to be for an automatic, so I'm stumped there.
85 is cannister purge circuit failure. What do I do ?
91 and 92 seem to be O2 sensor, so I clean/replace it ?
94, 93, 99 seem to be E40D automatic. What's the response ?
81 seems to be idle adjust solenoid. That could explain the unstable cold idle. Can that be cleaned or just replaced ?
Thanks in advance for help !
Old 03-11-2018, 11:52 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
NotEnoughTrucks2014 is online now
Interesting.
Your 88 F250 will not have MAF. Unless there is some modification we don't know about. All those 90 series codes also do not make sense given your vehicle description.
Is it possible you have the incorrect ECM installed? Check the ECM label and the calibration code in the door.
Old 03-11-2018, 01:11 PM
josiewales's Avatar
josiewales
Calibration code: 8-53E-R10
TRANS is M
But I couldn't find the ECM. Prolly don't know what/where to look for .
Could this be the ECM capacitor problem?
Old 03-11-2018, 01:17 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,360 Likes on 1,074 Posts
It is behind the kick panel next to the parking brake.
Old 03-11-2018, 01:52 PM
subford's Avatar
subford
subford is offline
The number that is on the ECM may be either: E8TF-12A650-AE2B or E8TF-12A650-AEB .
But the part number is:E8TZ 12A650-AEB
Old 03-11-2018, 02:06 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
I would check the codes again and verify you wrote them down correctly.
josiewales's Avatar
josiewales
without removing from the mounting It appears 9K02 C0L . Couldn't see how to remove it.
Old 03-11-2018, 04:19 PM
josiewales's Avatar
josiewales
Well I got it out. As best I can read it E8AF 14A459-B . Can that be right ?
And, yes, there's a cap on the board looks funny. ha ha
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAEAAAAAwCAYAAAC hS3wfAAAABHNCSVQICAgIfAhkiAAAHiJJREFUaEN9mlmMpOmVl k9E/LHvERm5VmXlUlVda3eXuy0L3M20DTPy4OnhAsQ2Am4QSIwQYm6 445Z75AtAAgFmjNF4MMwIpLkw9oyxp9ttt11d1eXs2nLfY9/34Hm/P5NuWkCUojIjMuL/v3POe97znvN9gX/6z//1zPM8C3oRCwaDNp2ZTSYTm1jA9Mim0tbptGw0HFqv17V+u2WeF 7RMIslnJmaBkM34qL4zGo3cczqduudsNrMh3wuHw+7a+luv17P xeMw1PItGQly3bTadWLXesNHY7Py8al44bjdv3bF+f+C+/+LFcxv2u1avl20y6ls0GrJwKGhr61esWq1aPB61fndgoVCIFQf d9WPhCOvuWLvVc9cYDgZuTaFg2K0nFApbIBAwT/99/qH39E8GHB0dOYPjsahlUglL8TMS5kaTsTU7bZva2IajiQ0ubhC LxSyZTDpjtYB+v2/tdtsikYilUin38/T01F23121ZLBpwxkwmU4slMnynZ8HQ0Grlig1xajQadcbYFKdh 4GgwxSDux/11HTlSBmvNura+f3Z2hmFBt/5wOOrM09/lIC9EsAmG/qagebyNqTz5Ah+7eOorM/elubmC89hw0LdGrWKz6RAvJi3ABcbjkSUwKuSNiWzHLajb7bob aFH6XY5ptVrO+I2NDUun086hk8nIOafX7rKwoMVicYsn0xbDiA EG1ut1d/92o4GD+zbDYELIuqbEOGAToNputpwRiUQMR8Utm826KIcJUCKa 4P2EnZycOQSMh2O3Ln2Xi4E8H7EggLec8bJZP33DnStYwPn5OQ YG7eRg354+fWJTIpvNpR0CaizgytVrlsnmnKF7e3u2v7/vLqXFxONxFxWhoVwuuwgUCgWXBv5jipM6LImUGRPtSBwDgtbpK k2mOCTh3ncoZdFaXZAUlfNDhE73FPx1Dxmn13KqnKCHgz5P3X/CdXT/aZAnfx8M++6zXjDoOQcIBcofOUBPPqYkIC+HFk+kuFHYEsk4hi t/ZtZsNa1Zr9jHRGhp+YozdtDvWR+eUFQiYc/CXgiIRyydSrrFtfnOjHx3uTojeVhYBo6ZgQalDkBwkPcwyPPCV pybswZIiEbDQFtwDnF9vkc0hYQ+vIDd7jtKtxoInY587pmSMo1 Gy/FLgHuFlAJypLNPwfWfFykANIj+LEjmiwXdBwNcHJIgxxJ4OaYn 5DMlMtyFhXQwdGgTLt5s1iGnMZHwrJDLW7PdcPBstRqWzxYsmY Y7IM0gd4tFYuJNfkYtzPW7fHaCk3udrkNbJJYkuhGH9gkoi0Zj bh3igDBI9PQdyDHKvbTKKammdBOq5GQvwHqBvtJWTtHffELWun HOSPb5JA0YuN5F/gsFvm+IvH6RM8BbMZ8jbxNWLcP2yp1x3wa9FtBt8hGx/MBq1bINYz3zop4lcdR4ErUBrEyN4LMdC0cCkGccY4AqDhMnNGp V67SbvB+zGRGeTQPWoRIId5HozJFZEsT1IbHRIAZ6cBRIcZVFD gBdSo1MJuPQM8J44VcGN1t1F6AG6PRwpr4jmxxZErwALwJEIQL kXBXQH/V0CcBrGepAwKPX74AAIs/NLSA4TRzhNVs1/hqwUvGqDR0LzxyUlVcdFjsGirF4BEY+sXrDs06uZaX5IlGMUhU gNnJQaSPDFFnBYkC5VbRcPnfbDkHK79ksyXeajixHkPGQ6tGR8 yHhk6NjUgaSJtcVeRkrNEzDcIZIT5dWioNwpYVzBt8VEbvnhZ3 uwyMgN+ZD8ryiXyfHibtzSIoSqFy0MZ7j52DYoaTErFw5s1QyA yw7EF/GwTkD41cqVcpbnLQJQ0JDazZqru7n8wWLkFYitR5lNJ1JkgYtj BlYtlh0Dmjz2oJTHFd1fCLkhClfY1Ju3CPS5LwMicUijk/k9EseEJsl4wnr4kyl7wx7ArIN1Ig45YwJKAhCtt3e0DzdUB4JB iMW5SbTwRDjes7brrZyM19gKMIiGGon6eFqM48q8PdCEQcvQbs PEQqSQpDq/0xkx98kpOQI5bnuKWYWmhpnRxZNJy+qBYskmnMgRYbrenoociM +q3uLR0JK24s6rjX6UfXrvKPzkPjLX7+coMfMU0ISfQIbwgku/0Gdl+bmgqMXFiRwgPQdUJbRKXK/3axZqO8b4dKF5+VFBTWht4e3RTi6qRbeB7ZDHKGoRGHuUCB6QU SIj9HALUhc4SI4l3PsLie1Vf4wVgHQa9V/6QxdUwSmEqh1YbsjXZ/csATiFoNht3P85Tr1e5g1yUEhUCQEzcYKtp/uQrI3V8rZ8fGxtZqSoGEWMOHClCoUnrwkARPg98tUmYmeeWghW lguVwRufRdRVQG9r9ydTmYubURmiojIiJXynZmLqL6rvBUsq6S aFpnMpEkPZC1IEaEuFRchUWBPWk2nIUegsn4yBIkXhup+crwel/yha12WO61LdkidkikoyD6f9wleGsK7d/u2g+nh4SE8FCTX0Mi4Wl6covokidtEWCXGf88vIbpxlDSQ5+NE MsjnhaQw9X88IkoYpvwTwSnCl5GT6BkpBSREBmPb3Fx3xmrByb Qf7X5tYJ1eG9jjCHQKd3RGOh4AGYSICASdwz1+jsd+eOQA6YuZ 0leowC+jycDCATQMVWgKaQ5dBfDTSpzmVWtlJ3ElIpzn8I7SQD eS0GjUa5BFEyPDTqbiSiIAlECloqjPJSVhY1P0fcsZKuj77K1F iIldfcGhQBE0RCJIaVYhDXF0euLK7wRnVZs+6ycQTtlins/MqCJlF1kZH4JrZJUCJR6SYAKyLvq6nrsXxl3mvyIf0XewSEHwU 0OCihTFBn3O++CD911HJdjpjR44UbQHvO5Q66NEVJAOBtIWx2P joU9+IjrBOkSEskjh5eVle/XVV53xW1tbrgZr4eoPJEp0c1eH+anyp88FqeUh0KK8Hw6BtsgS 1HWBqqrCDCQKHWOIWUFB41iEf7quBJCcKogrLdUoBZwkprnifq MwTRX25HI5V0L1UCrp/lr7GP0ilehtrm/Y7Vs3LVfIuUVp4U3YezhU69pFxMzso4cfUMbKpEKV9865UBuZm nW6/uzslJtE7Stffcvefusd55RvfOMb9qMf/dAhRETnZG4o6ryuRXigIOyBjjC6AYOnwbEtLOVs48YGpBezKuW vR7mLxRL2fGsbXSEFR8SJppDgiJZSNlJZnNLmgtyAu6Zkut8q9 9TiY2w+n3WpKWJ3fIBTRH4OgbwXeHnUmO3svoBxO0Tel5MBbtL r+uImX0jh0YG92Pk5ORqkjNGCBqNWrw7sxo0b4K1jV65csVplD Aun7cMPH9v3v//HlLOZvXz53HVjy4srfIdqA7Im5GSnXWYhPVtcLdkZNT9VTFl2I WnFxYxl8jHrE/3pBM2QLNn+87I9e7xvHa7vUaolXsKRIPzRcs4cwyOihDRSW06T GGo3Oy6YY4Io5k8gpyOgzVUWqpNIWJ9LpuLmdREjggOocV8KWA KIpoEYntTgIDy00/IL0uDUSgsLdufOGnyQtscf7ZEuqLgwBiRXIDX6/CPUIXl77dpV6w0bCJksHWPNMoWsjfsBOz0/czePJ4HgpGMvD49s886GRbP0BRn4JNSxHv8CMVbhMTuIBa3GEK SNHuh1qSpKB7SIpHB/3CIBQJjnq78gqRqk41NzJyKYUSbEMUHyZgTUKWRO6YaZZwSmEC tpI53hCZ4qdbEEAgJYqiW+dIAcUm8eO3KUM9TLq5wEAxH3s1Qq EuGKy/nT05Gdn/a5KD/LJ1apH1tpMW87h9t2Wj3B+xELJCg7pMIgOMC4gq0UEzZ/9arFUkyM4hArSEvmIu662VTBQpOU/WTyxLXJHk5JxpPOgUNkdjqWIvAQ6wTSdlUPbhDMsVVPzKcakWZ AfYRmGJNmYn3Jc3WH0jA9yMaTIXJAPCnRzMWBlLwzRjD4eeK3r yKuyw5rMu46MbS6etVu3Cw40lxYmNjBXt1a7YGVq6f2cGvXYpl 1y5Uy1uzS7XG9GSQ1IEpjCLZYyloepBQXl0EZ5BfqghpVnKG7R hOnne3VaMKqVBxKHUb3Qc0IIcUoxhJpj/ZbXWHKuDQOoPQib9VU6SlEUNEtzUxBLbgqSgLkJXlKvGlY06Xf 8CbkiRh1BuSD9Plu4CCX8pTcLNLetlqHNuwxaMCTcdrYAJ7sNa n5EI6apxQd2flZDSQ8IS3g6ynCaNq1Wqdi+YW0FSIJIpDDAJoq SDJVyFgkiU4f07FBTB4dZjCC83VfqkGr2bPzo4o9fO+RZYLz8E LaaLzhGJqeHmxPn5Arpq3WqDM2C/sIUM3jqS5PROzRdntMqqqUcWkDOaDTD1qjhZ38Lv4QKbpeQOSg iKvx0cOv277g0d+FBLGrnop8gLxSWijy0QiMPOgStYYACcSYCR Rzdvv2Tdu8u2aL66v2o59+ZD//+BlzA7AZTVq0PW+5hZzFQrTXAYYhwb6lIL8w6RjkPc0AouEY4o Beo3Zu6SATnfbM5rIlFjd1VcLz1GDRIUbz8IIvz50Quniob5jM CBhqVMaH6GTVzVI4uSyBpkWPkw7Y8+mQ0G8q/CZC19EF1dDIIWJNOcBXhP7URa8leJSX6stv334F7TCw6sdlJGf Pyo1T+8X3HtrDZ7sWTi3Zl379q7D9urVBUh8Yh0HJYO8pMwbND ihNEFy700Tnq63uSvVaWnKVCVAiEbFX790A9l37xS8+BMZ0qLz X1giM7/oCC2VIxxlQ74KKVC+hWYS0wQzHaYA75X0hSNUkxGe9SzUXgiUD fDAEjJTrk7HviDDw7cHwcoYgI6NFnDFISY4ZqelJxF15/PF7PyFiTWsP2uQfGr9ZsSvXFi2+WLTU3Ibllq+R6ylLhJPwAc6 sn9jO0w8hL2YOE+WsjyyJr9QifcArHTv85SFG91GhKcptAY5K2 sNHQ4e6ACNuj/KmICZTaAQ0mhuOjLmOSBC9EGdgKgHlSQlKRfIiGJ4RON9OTy0u CLFsml4eUSFZO0FbZ+kSHfSBYqW64+Z3UaLtJC5IUzfmKe94pL jJ0tKS3bx5E3h2bfd42/qVumVKTHuoLHmqR5dot9pAF8avN9p2xJD07uaSzVMp6kdlm6NU KjqTEcMQGDqbidnG6hX74s379t7337dEMEbFeWlvvvkmQ9goap GuUUMaCK3d0tRJA9aujStq55ktFNJ257VNkNR2v2umKVT0mGah lyzixnykgEqd4LtAjQ8AK4kNv2L6ydQfdp1XZbgcojS5fEpJwY dunteo1hxTFwpzNqLktKcoRmp6aT7PHJUFV/pWKR+Y1XsQdtLNAX56/Nw2c1O7trJEajMgIdJLpXkmQz07QSMUkznKptkbD+6qQDkSPjj esfxc0tKzuJXrLeDOB1CBCzjy7IzqUlyw/eN9nNCyjx4/ttcf3LRMLm5zpbx1QeZ4ppFdH/j7jZWnWRrgYMaGJRdN71BT15maD78ihIm0NhpUIfTU51QhZurT gYM2NqaQ6MHBITWf6FYOrTE5tqWNLHB9BOHNWTg+Zwu0zu2uP1 dcpjwFaWS8CZNiOL5e6fppxnw/BVEGUxO7unTVqvvHGFciy4NOEGlWsPnKOs1SAYPYHDlu287eIe V4w5XT9c1NO6nsUSXylHZ6A/ZFvETQsiXKZb1vxSwOJqjZbNrxjedm5jKEx5iR2GCAkKGkiQOU 74mUP38XB/gkqYrg9/2a2Wu6MsVh+lshP2/puVVLVvP29JBmil7i3r17aADtAzAmD8HgaITtF8eImjRiB1E0r luXaF2/eYNJ0AKjtAoldmBnxxXbfvzclkAU9ZGFZ9w0KJfOWpdIR6nnEf K+0fS7Vok4EWGSXqJ8NLT03ZTdf/0+lQXOwhEJUvrF3jMUZNfKVJY8aVGr1fwUmM3IJR5yhBzinIID ZHSvpwnR5YDRd0pEcwAIRe9rrKXJsv5JhnrMAT0vCRvDIWSTJk UNhi3xGNPbRNgerF+zHI3N0sIK8riLhlh2e375TMlmyOXgCMIl vzOxvBWXc3ZzbQ3XoUTJhZOTE1u6tmZ7bH010P0dIqjBqFppTa c111D3l8JnCp5TezR9gzFkCen1CW4U5MXoG3J5UKWR+2WbKuJQ ibuUvT7Ta7bnt5fiAF1Uhuun/z06OVAgMtTreq1lz57v2LMXO5TDITtIBWYHE/YG0sheBBW9f4paHGKqu8pCEhIjCKrF4goG55hHku/3v2ilwpJNEC1zhUX71T//Nfvyl9922uDxx0/Yj2RcTvtdgCuyhaIj39dff90NWxGAVLCIvfnFN9z7tTrtPOXbg 4NorEmJjBNLI4i/Cn/U2Th1QuhyA3NIbvijKwcIF2GPzssXP2offTTobzLY30qmutKvB 2g+FpG1K5vzdtIq29bhT0BQk4EETuMeYwju6UcPbTVRsiMUY+r eq7Y2V7IB/FHjb6eVsjMwQke5/ezAug12dbNTdpjYM0R9Hh2f2/PtY7t7XgZZUeQ1HSOo6zCiX1/boB0GffDY00+eE3lUhgY1bOHtbB8Q6SC/J4EFEohlqzU3VGWaSuOqgCJ6yexu0wCmGxM5Nz4m76YoKhmvfl 5DiFj0cpKscRTqj749nSaNZmU7Ozqw3dNdPHyKDObGDFZHdI2F fN7u3bpnv/nuu3b68oBUGaEZGHsDxydPtqgWS24HGn9Ykp8LuTXqvzY32E8A PTMk7tXVFdh8Afj37JefPDUP/d85q9va21+x0tKCXaMtf767bds7O9T/qL21+RboLPJd6jYcIUf0ace1hRJAa4gXglJcYaknDM/mMm5TU7kjVPicMHC6WcopwshajvIRQEOBCJJOaBONESn0zp990/76X/6aJYOcCWDx40rTWgcV9HzOJh0P56DdKZV1zgTsialX2UAtsne4 ELdPth8xFA3Yo0fvoTcooAxfBtRwzSq7rMXjPl0Senf/0O0ca5/vt//e37W/8e6vW5TrPfrZj+hGt41MsSyyulbuWqd8bJVttMPaut3IZC1Jo5 UnRTw4Q5K41UcTKO/9XVR1gzRGTG1FglPyBPDiGHXRwrxvuPbV3JOHnNEBbks0THfuL HEdWC+UsH/0D/6+La/l7OnLR3ZGSfwP//FbFllM2rXVGzZPaSsuLNrG7ev2X/7bf7X88ipKLWIP3nzNjnYP7O69W7YLj8S9OM2SJHjK9g9OHMEm UlnuieMhVpXg3/u9/2RnHz+1r//Fr1mgwqiUde3u7UB6MxAVsp2XL+yf/PY/tDT89fDkyM53EXTscgXzECGCL6z2/LONjghOr91P8bqmq+SMy/eLh37/7GsNJlW64oilCYOGCRXlCm3yONCyf/fNf2/XNlfsH//O79hf+yt/277+9d+wb3/7O+wm1RmBXbUv/Zm3mdJyUoQKof18GwbtnV/5C7ZVfGKHu8f24tlzrpuEteP2ys27dnRWsaXFq7a9v21XVq7BL wFbvfWKTZj5T1F2v0Z6lbY+th1SYOeXL+g1BvYv/tW/tADbaasry3aHz+auzFmNUnjQOLMgQXYOkPZ3cztpZppokZ7KoC IcvJC7/9sDAsOFEy51wQBumF9Qnc4R8TYGVhg0jJC5y/AJQ1MY+i4D03KlYQ8evOFS6vs/+CFRiFmHMhYbhW3r4+dWP6/ZN7/5LYuiRpv0FFGc0u+PEC4Te/8nP7PdnQO7B+NfIzzCY5G2+mD7hW3ThzgnMDFKwxdff+1V+4PB dywOmj3SplWru62xnRfPbXqAU+cyaFS0xIQKIbiL9Pzo+zLXJz wR3ximzPw/ESAHqDzq8xUR2gx6CadoRtgwgUt+6+/8LXrwlv3gT/4n4+8zmy8E7ae0xikETBV+uEcU/+Dbv48WyBNNz75w/4HVzhsu6i/Pd0FWzR4/+mecUpmzA7igSv9/eEqnSZe3xBT6na+8ZX2lBPwzIkXLdK6n7EnOL5Fi16/bHAS7+9HHtsBa7rL/0Gqzjc8W2d3XX7MOw9id4z2/DGpK6zvAz20/wn7MPw/5z77WSEqG52F4dZEiw0Jmzp4C3T/64c/srHrIYKRn77//AU7mpIgEJ+VnD3m7uDhnL17us3UVteP9U7q9uO1nT9if1Mhsal GUYrdz6jY6P/z5R0yQSpxGWXPplp8rwk5he/+Dn9vVtSV6D06gMPgIZziuA5qfP3vJ5+etcXJsr9y+RbN15M4z ZXJZ5gBGT3JOJeH8gpSgSqCnDUd+TtXm8XAzAsrOdOqf7tJ7n7 L/pxyg9zRS00bFFmXpD//7H1OfJ7Z7ssv2dNdWry/jFLQ+0R2MkMMYv7X13H7rb/5V++53fxeuWLHTk5ptXr9hG2ubqMG8O+FRIxVUXpU6Y9KrWCjZ u+/+Jds/PGDxDTcxmjD+CrOXuEFfoJNfhULIzk6r7E9ctc2NNbu2MG//+Zu/6+49VdsOQl65c5tJFFph+6lbs2aPnl//fdEjSakhoh7ihRl19v//8Hd9VEVUPh984Qs0H/TrW4/s0ScfEOl9BqNF2s6EnVd2me2zUNTh73/nu/bWW3+OKEfsez/4U1tZWnUHKhozJsx8do7F7+3tu0Bs4hjN91577QEMf0DLfYsx2 NidOZox7FiZv2L/9lv/huanSIrU7BZbfSd87gkj72q1bjNK+jyGThj5P3y6RboySeo1aI 5U7imvuolGQ3KE6n8Sva73huhmnQKLw8CX1UGfGZPfyvlL8lQZ 1VD1jJqr42lbL3YhNoaXiKdUNuUOT0iiaufo+KBsb3/5V2x5fo6SydAE1Omfon1ladntUImT7t+/z+mwJprgEc2M1hOx7e1tt0Ydr0vRGCWYEM+zjV45KTPIZ1aIcg z2J7b/bNuub6yz57Bhf/T4D20ObfNjzh5S8WxxqWi/+mtftfiMTZ1SwY5POVyhjigWL7EYH+4iNUdsLPzzJfDzaJA0yC Ewek4KB21lZcW6jKK3NObCkBj9fIJOrMxkt8p9JLvlvDhRrlDS fJRRs4nQPE7RZmqz2XTTJY3J3PE4N/ym2eG1CpKO7S0yLRKp7m3v2CvXr9JWSz3GrQC752mTl5kJZBLU ebREMs0a6AdUMdQpjpl6naIeNaGeUYI9bY2rNZwwkhKUL3NdC3 WHkz7z8P92IYgu3pchCXZ1NU+YMN0VMkSK1U7MHZ7ywhlX9jSS zjHrH3AsTidAjpDMt7O33Iz+DJHSZWO0BNFtbKza4nKJqRGa/8nM0ln/wFOJiPX7K262f+XKqq2vr7t9gDijriBD0RDPYipn82rJ0RUIPY 7T0Cr3qGS5FOJrGaTGGJIyVuNYzYCOM8QJF8+dpyEylzM/t/2M8Xqt5uKzokcO+Iwmcn9TiVKKNOp79gmNyMEZrS9SVMbEcoL3 kL04ndyKWz7FWQIdnkR+d1ptBFCYtjTrSFgT21w+6Zz2p++9ZI 9hn0gdQMz36SwZsTNgbbaqVI6nbMLQFpMypSJDlitrroJoRCcU RiDEGfODAd3oCCNnOvvIcGeiPISEtTEz4qhd9bTB+tEJ2uAU5J X3ykkZL0PdthivP//wSdPfNJEDOszjBPcILecXIKo5eOD54Us7goiSgwhwnXc3GkJCu eUUTU4J2G5aFNm9fm3VHb0bDnSNNgbmmdKwWcHQco6x+WKNGQF Nk49EjbXhE5oZHdiIcKKl3qgA8XukBnsDBMydA+aAhThDR35Cl FhkHu8xcmdGEY+mCcKc5eIFzjGxFynnK28vu0H9vOwNQgwh/e1sHwWfGv6pS8QBeThA35mOq3YElPdJKZU+5atGaS0dhWM2PwS VOtKqCH/yySfM/LbJ845dv77uTqUo909ODt33BO9GA+LbCdrxyYGV5hZ4nwaJ5kh 7hRnqvXan+9pFYrbQA2W6lzvgQbPjntocYTd5hPiIhpk90LF6s 7D1GwOrn9Yswe/FlTnzNDgQtBR5IWHMF2R4mI1JbY9DJf8XHvDfEgLEIRqEauvMp lU4HQ5gYNEapqn9bctBRgVe95t7SOFzO3x5ZM+ecIgCRXZ6ss/kmP17EFCkjImLGpSyEZpBJ8LfeOM1dP0eZxc6TMUGTHv8E6vtD ifLGYsHpS8gTlS7M16DjgHjOSFIm6OaUQTghhidZCxImiCrz/dP7Bc//tCe0tmesxYOSXnA7mL+h6e6HU5bkg5yBk3X/8EBn08HvU4zo1PrLMEiPhjilEqv6gxauHaDHGYnFyI6g9mDbJA Kem+g1d/58pcoZzG2yoL2vT/5HwiquNtYkdLrsGf35MkTFwiR5eFh1Y6vH9lrr77B8HMTGV135 xh0ROJ2+gFSWsdtqRUgqUvjo/TVQ9ykI/cKbpTUSDMRmkumqFx5GzFg7dTb9r8Ac42XssMqY10AAAAASUVO RK5CYIIA[/img]
Old 03-11-2018, 04:22 PM
josiewales's Avatar
josiewales
Picture didn't paste in properly.
Old 03-11-2018, 04:52 PM
Lead Head's Avatar
Lead Head
You need to upload the image to a hosting service, then embed it into the post.
Old 03-11-2018, 05:48 PM
subford's Avatar
subford
subford is offline
That is the number of the connector and not the EEC Computer itself.
Old 03-11-2018, 07:24 PM
josiewales's Avatar
josiewales
Thanks for the help.
Based on the condition of the capacitors and the pictures on here of other ECM's it seems I'd best just order another ECM. I'm thinking Rockauto but they seem to have quite a selection - which should I choose ?
Is the local NAPA a good source ?
Old 03-11-2018, 09:15 PM
Lead Head's Avatar
Lead Head
They're all pretty much the same. They're not new computers, just old ones that have been cleaned up and tested.
Old 03-17-2018, 12:34 PM
josiewales's Avatar
josiewales
IT RUNS !
So I ordered in the computer I was told to. From Rockauto, with expedited shipping. It's a bear getting back in thru the rubber gasket and firewall, but I stood out in the snow and did it.
I let it idle for 5 minutes then drove it for 5 miles. The CEL came on so I hooked up the Inova reader and got 11, 10, 41, 33 on KOEO.
I know the 11 and 10.
The 41 is O2 sensor, so I will change/clean that.
Then the 33 is the EGR valve - I guess inspect/clean/replace ?
But there are no codes about auto trans !
I am so thankful for you guys here that chimed in to help when I needed it !
Old 03-17-2018, 01:28 PM
subford's Avatar
subford
subford is offline
Continuous Memory Code 33 indicates that the EGR valve did not open
with the engine stabilized and with EVR solenoid duty cycle present sometime
during vehicle operation.
Possible cause:
-- Obstructed or cracked hose to EGR valve.
-- Damaged EGR valve.
-- Damaged EVR solenoid harness.
Mr StreetShovel
09-24-2018 09:04 PM
quincyj34
07-03-2013 03:44 PM
Bohatch2681
11-07-2004 02:59 PM
CoolSpot
1983 - 2012 Ranger & B-Series
07-01-2004 01:59 PM
bufordt
03-14-2002 04:23 PM
Quick Reply: Need help with codes
