6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Could this be turbo issues?
Old 03-23-2018, 06:17 PM
pbsdaddy's Avatar
pbsdaddy
pbsdaddy is offline
My 08 F250, 6.4, with 71,000 miles has found a new noise, of late. The truck starts, runs and drives fine... except, there is a humming noise that can be heard at operating speeds. It is louder/more readily distinguished at a stop, with the foot brake on. The boost gauge only gets to about 10 pounds, (first line), with normal driving and will drop off as I cruise. At idle, it is zero'd out. However, if I stomp on it, everything is forgiven and back to normal. Boost gauge jumps to 23/24 pounds and stay there, as long as I keep my foot in it.
The truck is stock, never had any after market anything and I bought it new.
I'm think the slow speed turbo is out, or has developed a leak. I'd rather it be a hose leak, but, my luck doesn't run that way. Any ideas?
Old 03-24-2018, 07:53 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
had the same noise
I narrowed it down to either the power steering pump or the power steering box.
I added red lubeguard transmission additive (drained enough to add the bottle) to the power steering resivoir and the noise went away.
theres probally some under lying wear going on, but for now, my noise is gone.
Old 03-24-2018, 10:38 AM
pbsdaddy's Avatar
pbsdaddy
pbsdaddy is offline
Originally Posted by speakerfritz
had the same noise
Hmm, a little dye can't hurt and it may end up saving me some money. Thanks
Old 03-28-2018, 04:47 AM
pbsdaddy's Avatar
pbsdaddy
pbsdaddy is offline
You nailed it, speakerfritz. Power steering pump.
cuda66
03-25-2014 07:04 PM
BigNick98
15
02-04-2014 11:17 AM
jtbutler
11-15-2010 02:40 PM
emmagator
03-25-2008 06:42 AM
Jspafford
1999 to 2016 Super Duty
02-06-2007 09:47 PM
Quick Reply: Could this be turbo issues?
