48-50 F1 Headliner install
OK, i have one of those cartouche carboard headliners and i saw many posts on here about them and others. The only issue i can see is that i don't have anymore than maybe 3/16" gap between the finished steel headboard and the roof. I was thinking the headliner would slide in between there about an inch or so to hold it. Also without being able to do that the sides of the headliner do not line up with the contour up in the corner near where the headliner curves and transitions about the door(off by about 1/2"). I looked at my 52 and it has a good 1/2" of gap that would allow me to push the headliner in there and adjust as needed. If this is an issue with my 50 then i'm going to have to trim which is not something i wanted to do. Here are some pictures of the finished headboard that i'm talking about and i tried to get one showing the dry fitted headliner and the gap caused by not being able to slide it forward between the headboard and ceiling. The green tape is for my alignment marks
Anyone run into this on a 48-50? I think i'm going to have to trim but I'd like to know how far it's supposed slide into that headboard/roof gap before i start hacking.
When the time comes I'll be enlisting the help of my wife to install it. She has helped me in the past with my projects when something needs three or four hands and more patience than I possess.
She helped me install a black vinyl roof on a 1968 Chevelle on a hot windy day, and that was one of those marriage testing moments you hear about.
Any tips I learn on the install are going to make this part of the '49 project that much better.
Tom
There's definitely nothing there that I can see or feel. I'm going to see if I can look there with a mirror. My hope would be the old headliner stuck in there. There is simply not enough gap otherwise. I'll report back what I find I just wanted to confirm what I already thought, that it should go in there an inch or so
More like a b/w photo of some 'It' girl. Like Lillian Gish or Clara Bow. These trucks were mostly used by workin' folk - not dime store cowboys.
On the install, it really isn't some sort of epic battle. I installed mine solo - even test fitted to get the center bracket screw hole located properly - in less than 30 minutes. Just remain calm and use the screw point technique for the hole.
OK, there is definitely NOT something in there. There just is NO gap at all the entire length of the headboard. I thought maybe it was bent in the middle but it's the entire way so i'm either going to have to cut the headliner and give it go or have it custom made.I think if i take my time i can cut it clean and use the 1/4" or so above the head board to hide the edge. Then since there is not a lot of holding room i'll probably use a little glue to make sure it stays up. Always a dilemna
OK i just figured it out thanks to you guys re-assuring me that there should be space. Looks like it is pushed back to the roof. I was able to use a dental pick over the upper edgea pull it out about a 1/4". It won't stay and it's finished in clear so i need to be carefull but i think i can use a spacer and then push it along ith the headlinder into the space This will be tricky but i'll give it a shot.
Got it! Love this site and everyone's knowledge. I was able to get ahold of it with my pick and then using a spring puller i got a good grip on it and bent it out about 1/4". Not quite was is on my 52 but plenty for the headliner. The paint and clear was hold it as well so i had to defeat that first which wasn't bad. Pictures when i get it done
OK today i Attempted to install the headliner.I found the center screw using the locating method, everything seemed fine. But the headline has some waves in it from being rolled up in the box and I can't seem to work them out. Everything else went up fine but these waves are not acceptable. I think i need to figure out how to get them out or get a new one. I don't have it screwed in yet but i don't see how that would help the roof. Screwing the center screw up only makes it worse. I don't have any "buckles" yet but i could lose my patience and have them! Anyone else experience this? Do the side "hinged" pieces go on the outside of the headline or inside or even. The instruction are a complete joke (cartouche) and look like they were reprinted on an old mimeograph back in alementary school. Bascially they say to work from front to back and screw into place. A joke.
