What is this thing?
What is this thing?
I hopped a curb the other day, and then noticed this tube dangling from my truck. For the life of me I can't figure out where it was supposed to connect. It doesn't seem to do anything, nothing has come out of it, and everything still works. Anybody know what this is or where it goes?
If you look right up above it on the frame, there should be a clip that it attaches to. However, make sure the hose is long enough so after its clipped into that bracket,,, the open end hangs down so no water is splashed into it. ALSO, take into account for the length of travel that will be needed when the truck frame is lifted away from the housing.
If it were me, I'd get new hose. Those hoses can get old and brittle.
Ulfie
It's a '66. Standard 9" rear end as far as I can tell. Though a quick google search tells me you're right, that's a non standard drain location. It would not surprise me if this was a DIY repair from the previous owner, the more I drive this truck the more of these "fun" surprises I keep finding. Looks like I'm ripping apart my rear end this weekend to make sure there's nothing else to see here.
IT IS NOT A DRAIN. It is a vent tube to allow pressure variants.
If you have never worked on final drive systems before, I might suggest seeking out someone's help before just jumping into it or you might do something you really don’t want to do. I've set up a few pumpkins in my life, and that is an education on its own. Gears are not cheap to replace but they are easy to screw up if they are not set up correctly.
But than again, I'm just a crazy old fart and most likely have no idea what I'm talking about.
I think the "drain" in question is the leaky plug on rear of the differential housing. I think that's a Ford 9 inch but I didn't now they had fill plugs there...might be a home made deal.
Anyway, while the OP is replacing the vent hose, I like to remove the fitting and clean it. Good time to replace that faded brake hose too.
BarnieTrk
kelwar,
Does your fill plug look like the one on the rear end housing of the OP, DeadFrancisco?
My '65 F100 has the rear end fill plug on the front of the carrier casting....... the rear of the housing has no plug like what the OP has.
BarnieTrk
Easy to check. Take the plug out and see if there is a threaded ring insert welded in. I've seen housings with a fill plug in the back and they were flush. BUT, pull the plug and see. Now I'm curious.
Is there a fill plug on the drive shaft side?
If ya don't tell us, I will never be able to sleep. :-)
