2001 Ford E-350 loss of acceleration power - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-07-2018, 05:56 PM
Sadam
Sadam is offline
Sadam is starting off with a positive reputation.
2001 Ford E-350 loss of acceleration power when trying to overtake. Catalytic convert is clean can see right through it. When i press the gas pedal all the way down it starts to make a clogged sound but if i should go half way with the gas pedal it revs as a Normal vehicle should would really appreciate it if someone could assist me with this issue. Otherwise from that it runs good i was also i had a lean code on bank1 and bank 2
Old 03-07-2018, 07:46 PM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
Clubwagon is gaining momentum as a positive member of FTE.Clubwagon is gaining momentum as a positive member of FTE.
It would help to know what engine you have.
Lean codes for both banks would indicate a fuel supply problem. Could be a stopped up fuel filter or even a failing fuel pump.
Could also be an air leak, like a split intake hose after the AFM.
Old 03-07-2018, 08:00 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
what exactly is a clogged sound?
also thereís no way you can see right through the catalytic converters because of the way the piping is bent. So what/how did you look at?
Old 03-07-2018, 10:17 PM
Spaznaut
Spaznaut is offline
Spaznaut is starting off with a positive reputation.
Your going to have to stick a fuel pressure gauge on it and check the pressure. Also just revving it isn't the same as loading like going up a hill. I'm betting fuel pump or regulator is failing.
Old 03-08-2018, 03:08 PM
Sadam
Sadam is offline
V8 ENGINE 5.4L
LEAN CODES P0171 P0174
I WAS THINKING ALONG THAT LINE TOO RE THE FUEL FILTER IM GONNA CHANGE IT NOW AND SEE WHATS THE OUTCOME
Old 03-08-2018, 03:11 PM
Sadam
Sadam is offline
what it is is that a simple overtake/passing will be useless as i wouldnt have enough power to complete the pass or even trying to make possible turn before the oncoming traffic gets to me
Old 03-08-2018, 03:15 PM
Sadam
Sadam is offline
my truck has 3 cats 2 upper and a rear cat the rear cat thats the one you can see through. on the other hand the clogged sound i was reffering to was the sound the enginge being deprived of either air or fuel thats what im trying to figure out
Old 03-08-2018, 03:16 PM
Sadam
Sadam is offline
thank yo all im gonna try the fuel filter first and see what that does if anything changes ill let you know
Old 03-08-2018, 07:20 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
You are wasting your time with the fuel filter. Thereís no way a fuel filter will cause lean cofed bank one and two.
Those two codes always 100% without a doubt positively always indicate a vacuum leak. Fix that before you move on.
check the PCV elbow, and the intake tubing, and you will find your problem in one of those two. I guarantee it.
Old 03-08-2018, 09:48 PM
GreeVan's Avatar
GreeVan
GreeVan is offline
GreeVan is starting off with a positive reputation.
Vacuum leak should be your first check as pointed. Are you having any issues with the air vent, like going to defross when accelerating?I had similar problem to what you described and turned out to be the vacuum reservoir.
Old 03-09-2018, 11:39 PM
Sadam
Sadam is offline
For all who said fuel filter you are 1000% correct changed fuel filter on idle vechile is reving out as it ought to going up to 5000+RPM fuel filter was clogged saw some brown looking debris coming out took it for a test drive runs like a champ really appreciate all your inputs now that problem is solved
Old 03-09-2018, 11:48 PM
Sadam
Sadam is offline
Re: Highspeed vibrations
Once i reach 50mph and above vehicle starts to vibrate like there's no Tomorrow however when I ease off the gas pedal it stops replaced front end parts tie rod ends ball joints as those where bad but still does vibrate at high speed i was thinking along the drive shaft would really appreciate your inputs
Old 03-10-2018, 05:25 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
I strongly suspect your new problem is directly related to your original problem, and that the fuel filter didnít fix it. I could be wrong.
Did your engine codes go away? If you still have p0171 and p0174 then you (still) need to chase them down.
Old 03-10-2018, 05:05 PM
Clubwagon's Avatar
Clubwagon
Great. Glad I could help.
Does the vibration vary with engine speed or road speed? Does it vibrate only when on the throttle or also when coasting? Low or high frequency?
Old 07-09-2018, 12:28 PM
Sadam
Sadam is offline
When accelerating once my foot is off the gas pedal it stops or if i accelerate more it stops
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
