Winch Install on my Truck
Received 3,090 Likes
on
ohh ive seen tighter... but agreed... i hate how close the neighbours are... im glad the new house has 5 acres to play on..
You are going to want to invest in a ****** block. Twice the pulling power and a lot easier on the winch. The instructions probably talk about giving the winch a break and they wouldn't be kidding, heat is it's worst enemy. I've burned my Ramsey out more than once. I buy parts from U.S. Winch. They are reasonable on stuff and have some used parts as well. Let us know how it holds up for you.
book says 45sec pull time at full load.. with 20 min cool time.. but i dont plan to ever be at the max load.. which is why i bought the 12,000lb one.. despite all the pulling i did last weekend i kept checking the motor side of the unit.. it never even got warm.. i was very happy with how well it did.. the only annoyance i had with it, was the line kept trying to load up in one spot till it pushed the solenoid box off the top... thought the bar that sat on top of the coiled line was supposed to prevent that.. but apparently not..
would end up pulling for a bit then drag the line out to hand feed it back onto the spool.. before i could resume pulling on the burb again..
Lil dually said she wanted to play moving truck yesterday...
I told her to go move the building on the back of our new property..
Lil dually said Challenge Accepted...
It moved a bit...
then a little bit further
then it needed to turn a bit...
then we had to reposition to pull it back into the last spot..
new 6 ton ****** block came in handy worked like a dream...
almost there...
there we go..
little bit of block leveling..
It moved a bit...
almost there...
there we go..
on
#29
ty..
my truck get stuck?? lol dont you know ford trucks dont get stuck... its the competition that gets stuck..
besides if i kill it itll just mean i need to buy a bigger one lol.. or buy another to replace it.. after all it only cost me $274 for that one
lol afraid your "truck" cant handle it?? i see the size of that motorhome you got there...
