1995 Econoline 4WABS issue (code C1113 & C1185) - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-05-2018, 05:23 PM
Ballo
Ballo is offline
Ballo is starting off with a positive reputation.
Hey, I've been having a hard time diagnosing my ABS issue. The codes I get are C1185 and C1113 when I run the self diagnostic (I can hear the ABS relay activate). The Service Manual directs me to fix C1113 first which starts at S8 (photo attached). The problem is, all the tests pass. I also went through the trouble of buying another ABS electronic module but I get the same codes from the self diagnostic. The only thing slightly out of spec is one of the solenoids is slightly above 6 ohms (spec is 3 - 6 ohms and it showed about 6.1). All the solenoids appear to engage when given a 12v source. The measured key-on voltage was 11.7 volts which was also within spec.
Anyone have a clue what's up? Thank you!
Old 03-05-2018, 05:25 PM
Ballo
Ballo is offline
PS: While diagnosing a seemingly unrelated transmission issue, I found a slightly below spec voltage on the transmission oil temp sensor (spec is 4.75 to 5.25 and the meter reads 4.61). Not sure if that could be related but I thought I'd mention.
Old 11-08-2018, 07:13 PM
Fords4Me's Avatar
Fords4Me
Fords4Me is offline
Fords4Me is starting off with a positive reputation.
I have the same problem. Anybody?
Old 11-12-2018, 06:47 PM
baddad457
baddad457 is online now
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
Me ? I just ignore the light. My brakes work just fine without 4 wheel ABS
Old 11-14-2018, 06:14 PM
Fords4Me's Avatar
Fords4Me
Fords4Me is offline
That's great!
B846B
12-15-2017 11:24 PM
Vitaliykit
32
10-28-2015 11:13 PM
wtroger
1997-2006 Expedition & Navigator
05-18-2015 12:46 AM
CM_3
05-21-2012 01:52 PM
BltFordTough
10-30-2010 06:18 PM
Quick Reply: 1995 Econoline 4WABS issue (code C1113 & C1185)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
