98 mountaineer 5.0 vacuum line help!! - Page 3 - Ford Truck Enthusiasts Forums
Old 04-16-2018, 09:56 PM
Thelionwarrior
Thelionwarrior is offline
Thelionwarrior is starting off with a positive reputation.
So here's the latest. I used a compressor and blew air through the steel line. Fuel comes out of the pump and to the steel line but for some reason is not going through the steel line? I don't get why.... I know air is getting through cause I put a rubber glove at the end of the line and it blew off.... but... fuel is not getting through. Not even a dribble is making it to the filter.... what the heck am I missing???...what else besides air can I try to run through the steel line?
  #32
Old 04-17-2018, 06:55 AM
shorod's Avatar
shorod
shorod is offline
shorod has a great reputation on FTE.shorod has a great reputation on FTE.shorod has a great reputation on FTE.shorod has a great reputation on FTE.
Do you have a MityVac that you can connect to both ends of that fuel line to determine if there's a restriction in the line that you might be able to monitor as basically backpressure. If there's very little backpressure, maybe your fuel line has a good size leak somewhere (that I think you'd see leaking with the fuel pump connected. But if there's very little backpressure the line could also be free flowing and the pump just doesn't generate enough pressure to push fuel to the filter. If you have access to a master fuel injection test kit you should be able to rig up a means to measure the fuel pressure at the fuel pump. Your local auto parts store might even have the master fuel injection tester available through their loan-a-tool program.
-Rod
  #33
Old 04-21-2018, 03:48 PM
Thelionwarrior
Alright! Dropped the tank and come to find out the line was pinched causing it not to put out enough fuel. So, fixed that. Now it runs!!!!! Yay!!!!! But..... smoke is coming from under the engine at the exhaust.... no yay.... now I'm out of my element completely and have no idea why smoke is cominh from here?
  #34
Old 04-21-2018, 05:14 PM
shorod's Avatar
shorod
shorod is offline
Congrats on finding the fuel line restriction!
Does the smoke have a distinct odor of either burning oil, burning leaves, burning coolant, burning plastic, or some other distinct smell? I don't really see anything that looks like smoke in the photo above.
-Rod
  #35
Old 04-21-2018, 06:27 PM
sawmaned
sawmaned is offline
sawmaned is starting off with a positive reputation.
is there old grease or oil on exhaust anywere ? as shorod said whats it smell like
  #36
Old 04-23-2018, 05:27 PM
Thelionwarrior
Ok got underneath it. Looks like its coming from the transmission area? The smoke is white but honestly I don't eecognize the smell. Not coolant I'm sure. Doesn't smell like oil. No smoke out of the exhaust. Maybe the seal?
  #37
Old 04-23-2018, 05:53 PM
Thelionwarrior
Also abs light is on? Not sure why?
  #38
Old 04-24-2018, 07:01 AM
shorod's Avatar
shorod
shorod is offline
It's difficult to say what that leak is from since it appears wet as far us as one can tell from the photo. Transmission fluid is a thinner consistency than engine oil and would typically spread out further than this leak, which has obviously been leaking for quite some time. Also, the drips at the front edge of the transmission appear more honey colored rather than pink. Pink would suggest transmission fluid, honey colored would suggest more engine oil. Based on this image, if I had to speculate, I'd speculate it's either a rear main seal leak or possibly something up higher like a valve cover gasket.
As for the ABS light, that's probably not due to this leak. The rear wheel speed sensors are a known common failure point, but there are several other things that could cause the ABS indicator to illuminate. You'll need to get the diagnostic codes for the ABS module read out to have better guidance on that. Note that the typical consumer-grade scan tools usually will not access the ABS system. You need to find one that specifically lists ABS as one of its capabilities, and then make sure that it is compatible with your Explorer.
-Rod
  #39
Old 05-15-2018, 03:27 PM
Thelionwarrior
Finally solved the vaccum line issue! After a lot of researching on the internet and looking around I discovered that vaccum goes under the passenger side fender to the black black ball thingy for the vents. Sheesh! Now on to solving the other issues!
  #40
Old 05-15-2018, 04:14 PM
sawmaned
sawmaned is offline
glad your getting it all figured out,
zforzimmer
07-01-2018 07:45 PM
jb50F1
21
03-14-2016 03:25 PM
geocraig77
2004 - 2008 F150
12-19-2011 08:34 AM
Marv Allen
02-03-2009 08:37 PM
impy
1999 to 2016 Super Duty
05-09-2004 01:07 PM
Quick Reply: 98 mountaineer 5.0 vacuum line help!!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
