Hutch/Harpoon Mod
There is tons of information on the FTE regarding this. I would encourage you to use the ADVANCED search function and look for "hutch" in the title field only in the 99-03 diesel section.
In the middle of the screen on the blue horizontal bar is search, once you select that advanced search is an option.
Most install the filter on the inside of the frame because that is where the plumbing and most protection is at.
I think one other benefit to the racor over the 4 micron 1212 is less strain on the fuel pump. The racor will remove anything from the fuel necessary. The main filter in the stock bowl will protect the injectors.
I used 3/8” fuel line for the tank to the PS120, and 5/16” from PS120 to the fuel pump. So, if you go that route you’d need one each 3/8” NPT-3/8” hose barb and 3/8” NPT-5/16” hose barb.
Also, make sure you get the Racor PS120-02. That has the 3/8” NPT thread size. I believe the PS120-01 has 1/2” NPT threads.
I still have my old base and filter sitting in a box on the shelf and as you can see from reading this others have been down the same road. At least you won't be doing the install twice!
Cant even install it yet, too cold in CT to work outside, if only I was able to convince someone to let me have a bigger garage next to the driveway
